Monolithic Slab Foundation only in camera view
I am always trying to simplify/template things as much as possible - does anyone know why: " If Monolithic Slab Foundation is checked, the current Floor Structure will be replaced by a single 4” (100 mm) layer of concrete with footings that can be seen in camera views only. "  -  why does not the Program generate the slab as a layer on the Plan View on the Foundation Level?  Am I missing something obvious?  I like how the 'Slab Footing' wall has a camfer option, I just don't understand why if the Monolithic Slab Foundation is generated automatically it can't show up as a regular Layer?
It does and probably.
If something is not showing as you expect, post the plan, and someone might have a look.
Did you check the Layer the MonoSlab in the Garage is On is Displayed in Plan View? it will display on level 0 though as it is considered a Foundation...(see above too) , I assume you built the Foundation of course....
That's my point.  Chief creates a 'phantom' slab in the elevation view, but THAT ITEM DOES NOT EXIST in any Plan View.  This quote is from the User Manual:  " If Monolithic Slab Foundation is checked, the current Floor Structure will be replaced by a single 4” (100 mm) layer of concrete with footings that can be seen in camera views only. "  I guess I'll just post this to an idea for future improvement.  I just can't figure out if there is a good reason that the slab does not automatically generate in Plan View.... it is great that it generates in Camera Views, but why not in the Plan View?
The mono slab DOES auto generate in plan view (and camera views)- on the foundation level (Level zero).
On level 1, you need to specify Floor Supplied by the Foundation Room Below.
And/or
On level 0, you need to make sure Room Supplies Floor for the Room Above is checked.
Then auto build the mono slab foundation.
You Must BUILD the Foundation otherwise it is not there , the Monolithic Foundation will replace the "phantom" Slab as per my image above. And once you build it it is on Level 0 not Level 1 along with ALL foundations. Once you name it a Garage the Floor will drop and you'll get the Curb.
If you set Automatic Foundations to On and the default is Monolithic Slab, one should be Built automatically every time you make any Room/House/garage.... ie join 3 or more walls.
If you always use Mono Slabs you can even set it up that way in your Template Plan.
***Beaten to it by Glenn :)
Or, one way to get a mono slab without generating a foundation is to name the room a Slab type.
If you have Monolithic Slab checked in the Slab Room Types default, you will get a room with a mono slab, but no foundation level (level 0) drawn.
    29784
    behrsbuildings
    behrsbuildings
  • Similar Content
    • By since1937
      How can I drop the foundation slab in my attached garage by 6" from the main house? All of the walls are already up in the plans....
    • By greglocke
      I'm trying to show my garage floor slab poured through my doorways.  I have stemwalls set at 6" above the floor, but want to depress the stem another 4" to allow pouring the slab through.
    • By GCCISarah
      Hi everyone-
      In the last several plans I have created in chief X11, using a Camera View with a Reference Display of the As-Built, I have the As-Built Reference Display file set to render as a Glass House view. The Glass House referenced model displays, but without any of the dark outlines to show the features of the model. I have included an image of a remodel I am working on currently, where the referenced As-Built shows as a faint blue shape. Nothing like the examples Chief gives of a reference display, below.
      Any thoughts on what setting I might be able to change to get the 'outlines' back. I have also included an example image from Chief I found online, which has the desired 'outlines' in black.
      This does ONLY happen when I'm using Glass House View as a *Reference Display* in the plan I'm working on. If I were working on a plan and change the rendering technique to Glass House, the outlines are visible. This only happens in Reference Display.
    • By GCCISarah
      Hi everyone-
      In the last several plans I have created in chief, using the reference display in a 3D view (referencing an as-built plan overlayed onto the remodel plan) with Glass House View, the Glass House View is very transparent, with no 'outlines' around the items in the drawing.
      It makes it quite hard to see what the existing vs. remodel.
      Any thoughts on what setting I might be able to change to get the 'outlines' back. I'll attach a photo of a kitchen I'm working on currently below, showing how faint the Glass House View is, vs. an example photo from Chief I found online, which has the desired 'outlines' in black.
      This does ONLY happen when I'm using Glass House View as a *Reference Display* on the referenced plan. If I were to delete the reference display plan, and just change the rendering technique of the Plan file I'm working on to Glass House, there is no problem. The 'outlines' show as desired.
    • By DaveCoyleJr
      Hey guys... I've been dancing around an issue that I simply need to tackle once and for all. Whenever I wish to build a simply visual layout, I get the perfect angle and hit "Send to Layout", "update Always" under Live View... This always spits out a box that is centered on my page and at the same size and scale... The issue is I can't figure out for the life of me how to edit this box. It is always unclickable and appears as if chief does not even recognize it. I literally can't even delete it and is usually forced to Ctrl-Z or delete the page and start anew.
      I know there is something small I'm missing here; To circumvent this issue, I simply "send as image" and I'm able to scale and fit; but then I proceed to have a hissy fit when clients want to change small things and I'm forced to go and "reframe" my entire model... PLEASE HELP! I just want to resize the live view to fill my layout page. or at least be able to delete it.
      EDIT: I'm on Windows X11 btw
