ggthompson Posted January 28, 2018 Share Posted January 28, 2018 I am having trouble with my terrain. I am in the plot plan set and have drawn my terrain but it doesn't show up on either the plan or the camera views. Several of the tabs for terrain are grayed out. Anyone have any ideas what may be wrong? Gloria Link to comment Share on other sites More sharing options...
JJohnson Posted January 28, 2018 Share Posted January 28, 2018 Turn on Active Layer Display Options, and make sure the Terrain Perimeter line has a red cross for used, and a check mark for displayed. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 28, 2018 Share Posted January 28, 2018 Maybe you didn't turn it on in the layer sets or post the plan for an exact answer Link to comment Share on other sites More sharing options...
ggthompson Posted January 28, 2018 Author Share Posted January 28, 2018 I don't have a "used" column in my active layer display panel. When looking at it again, I don't think that I actually drew a perimeter because it is grayed out also, I have all my terrain layers turned on, is there something else that I need to turn on? Link to comment Share on other sites More sharing options...
ggthompson Posted January 28, 2018 Author Share Posted January 28, 2018 I turned on the column that shows that the terrain is used. Still nothing. Link to comment Share on other sites More sharing options...
RL-inc Posted January 28, 2018 Share Posted January 28, 2018 Are you sure you actually created a terrain perimeter? Link to comment Share on other sites More sharing options...
ggthompson Posted January 28, 2018 Author Share Posted January 28, 2018 I did, so I went into my camera view and deleted it. I created a new one and everything seems to work right now. Thanks to all who replied for all of your help. Gloria Link to comment Share on other sites More sharing options...
Kbird1 Posted January 28, 2018 Share Posted January 28, 2018 1 hour ago, ggthompson said: I am having trouble with my terrain. I am in the plot plan set and have drawn my terrain but it doesn't show up on either the plan or the camera views. Several of the tabs for terrain are grayed out. Anyone have any ideas what may be wrong? Gloria If you "Drew" your Terrain manually ?, it is likely only a CAD Line / CAD box so not seen in 3D Go to Terrain>Create Terrain Perimeter to have X9 Place the default Terrain into Plan view , you can then resize or move it as Normal. M. Link to comment Share on other sites More sharing options...
