ACADuser Posted January 22, 2018 Share Posted January 22, 2018 Building these is a PITA, is there a better way? I just guess at the locations of the roof baseline when creating the roof planes needed. Once you have one you can copy but that first one is tedious work. Any ideas? Elrod.zip Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Share Posted January 22, 2018 Those are Called Roof Returns in CA and can be done Automatically in the Wall's DBX M. Link to comment Share on other sites More sharing options...
ACADuser Posted January 22, 2018 Author Share Posted January 22, 2018 Mick, Not the same roof, but thanks. The roof built can not be modified to look like what I wanted. Eric, Do not understand the process but will try again when I return in a few hours. Thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Share Posted January 22, 2018 I didn't open your plan , it appeared to be a standard roof return so I didn't go any further..... what is it you want to do? M. Link to comment Share on other sites More sharing options...
joey_martin Posted January 22, 2018 Share Posted January 22, 2018 Alan when you select the roof return there is an option to "extend" the roof return. Set that to 8"-10" and see what you get. I bet you get what you are looking for. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Share Posted January 22, 2018 5 minutes ago, joey_martin said: Alan when you select the roof return there is an option to "extend" the roof return. Set that to 8"-10" and see what you get. I bet you get what you are looking for. That would be my guess too.... make the extension the same as the Overhang though perhaps.... M. Link to comment Share on other sites More sharing options...
joey_martin Posted January 22, 2018 Share Posted January 22, 2018 Like this.... Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Share Posted January 22, 2018 If the Roof over the garage Door is supposed to extend all the way across you may need to break it's edge and drag it left manually and join it to the Porch roof. Auto Returns seem to work all right though in your plan.... M. Link to comment Share on other sites More sharing options...
ACADuser Posted January 23, 2018 Author Share Posted January 23, 2018 Thanks Mick Joey that was the trick. Thanks Much. Link to comment Share on other sites More sharing options...
TriumphantBuild Posted December 30, 2022 Share Posted December 30, 2022 Does anyone have a picture or diagram of the framing layout for this hip return bird box? Link to comment Share on other sites More sharing options...
GeneDavis Posted December 30, 2022 Share Posted December 30, 2022 I don't like a hipped return to have the same pitch as the main roof, and so lower the pitch of the two small roof planes that make the return, to maybe half what the big roof has. Which means I gotta build them manually. Maybe I ought to find out how to edit the auto-generated ones. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 30, 2022 Share Posted December 30, 2022 2 hours ago, GeneDavis said: Maybe I ought to find out how to edit the auto-generated ones. I think that Suggestion has been made , but currently I don't think it's doable ? M. Link to comment Share on other sites More sharing options...
TriumphantBuild Posted December 31, 2022 Share Posted December 31, 2022 I figured it out gentlemen. Trying to figure out how to send pics. Link to comment Share on other sites More sharing options...
TriumphantBuild Posted December 31, 2022 Share Posted December 31, 2022 I tried lowering the pitch to and 8. Ran into planing issues. It only worked out when I kept it the same pitch as main roof. First one took me 45 minutes to frame. The last one took 15 minutes. Link to comment Share on other sites More sharing options...
ACADuser Posted December 31, 2022 Author Share Posted December 31, 2022 So did you see this article? https://www.finehomebuilding.com/forum/how-would-you-frame-this-cornice-return or this: https://countryplans.com/smf/index.php?PHPSESSID=4f6426e5c2f5513d904b33535b7d0985&msg=168180 Or this? https://www.thisiscarpentry.com/2013/12/13/eave-returns-interpreting-gyhr-details/ Link to comment Share on other sites More sharing options...
ACADuser Posted December 31, 2022 Author Share Posted December 31, 2022 One more https://www.finehomebuilding.com/membership/pdf/401484/021285064.pdf Link to comment Share on other sites More sharing options...
