French Door, One Lock
Chrisb222
Can't find any way to show both panels active with only one lock. This type of door is very common here and I use them a lot on walk-out basements. Both leaves open, the leaf without the lockset has flush bolts that slide into the head jamb and threshold, the other leaf has the lockset and deadbolt. I can eliminate the extra lock by checking "Left Swing Only" but then the door is not accurate. Is there a setting I'm missing? Thanks
We do it the same here , please add the "active door" marker and single door hardware as a Suggestion , I'll be happy to +1 it.
5 hours ago, Joe_Carrick said:
Specify no Handles or Locks.  Then Place a Handle or Lock Manually.
2 hours ago, Alaskan_Son said:
You can also just use 2 doors with zero separation...
Thank you both for these ideas, that will work for now.
Yes I will, I would prefer to have the control within the door SDBX.  Thanks.
