RGAID1
Arch top cabinet
How do you arch the top of a wall or full height cabinet to make it look like furniture?
Depends-
First with full arch was a quicky since the cabinets with cureve were existing and doing a favor to add the dark corner cabinets. Used an arched door way, fiddled with walls, forced cabinets in place, converted from a cad detail to create the molding.
Second is not curved top but gets the idea- how it would be done IRL by adding a pediment at the top- make a custom symbol, that's what is on the top of this cabinet.
Third and plan slapped together as principle if you needed curved doors as well. Custom door (stretch plane defined to prevent height resize), mess with the cabinet and add a custom pediment at the top.
Arch door.plan
I did one similar to this a couple of years ago. I think I used polyline solids and 3d molding lines for the custom head and trim. I would probably create the front in a CAD detail and copy the linework to create the components and then convert to the 3D elements.
This should get you started. Began with a line, determine points for curve and add breaks, check the dimensions, convert to curve.
Then add sides and bottoms till it is a polyline. Copy in place, move one copy disconnect everything but the curve.
Convert the curve to 3d molding line.
Convert the polyline to a Psolid.
Mess with the sides of the moldings (tip add break points first)
Scroll work is in library.
If you want beaded inset and chamfers I've posted stuff on that in symbols a while back- not for the faint hearted that bit..
Have fun. This took under 15 minutes but expect to spend a lot more time if just learning this stuff. Save often!! :)
Curved top.plan
Chief has a video for creating a custom cabinet over a range/hoodfan (I think) which you should look for a watch ... with an arched top very similar to your image.
Go to the Chief Architect website and look around and see what is there.  Tons of stuff that will take more time than you have if you were to watch/read it all.  Use the search box and see what comes up.
    27475
    slickrick1530
    slickrick1530
  • Similar Content
    • By MPhillips
      Gentlemen,
      I have placed a dishwasher in a cabinet, and it fits fine, but when I do an interior iso, tt move to the back of the cabinet.  I pull back into place, but it moves on its own back to the translated position.  I have included two screen snips showing the problem.
      Does anyone have an idea of what I am doing wrong.
      Merlin
    • By BWoods
      I'm currently using Chief Architect Premier X11 and have been tasked with drawing this kitchen for a customer, as pictured. I know how to do bow fronts, radius ends, etc, but can't find any way (or tutorial) on how to do what I'm looking for. The customer wants a sink base with an almost tilde shape (~) and a bowed corner cabinet, both with curved backs. Is this possible?
      Edit: Also, for the corner cabinet to the left of the sink base, they want the lower portion straight up, to have the top half go into a radius to make the sink base work properly for this layout.
      Thanks in advance.
    • By tremhomes
      I am having an issue with a corner double oven in a cabinet.  I am using x11 version and it looks correct in the 3D view but in the 2D view the oven locates on the right side of the cabinet.  I have tried rotating the oven in the symbol specification which faces it to the front of the cabinet but is does not center on the cabinet.     Any solutions for this?
    • By habdou
      Does anyone know how to solve this issue with the hinges.
      Thanks
    • By habdou
      Can the cabinet have holes for the shelves, without having to adding polyline solids?
      Can we add stretchers for the front/back of the top of the cabinet without having to adding polyline solids?
      Something like this:
