interior wall elevations
cjanderson66
I am trying to do some interior elevations and I have a room with a vaulted ceiling.  When I do a wall elevation it is only giving me the lower half of the room and not including any of the vaulted portion.  Am I doing something wrong or does Chief not acknowledge the upper portion for wall elevations?
Hey Chris,
I do this all the time and would recommend a section view that is back clipped, and clipped to the sides so that the display goes just slightly beyond the wall you want to detail. Add a breakline to each side of the view and/or the top and bottom as needed. You can't clip the height of the camera ( that I know of ), however a white CAD box covering the floor below works well. Or the view can be cropped in layout.
  • 2 years later...
I have been trying to find an acceptable work around as well. I tried the "balloon through ceiling" with no luck. I'm not satisfied with having to do a back-clipped cross section or CAD detail to get a wall elevation of a room with a vaulted ceiling.  I think if the ceiling is higher than the wall top plate then it should be shown in a standard wall elevation (but who cares what I think lol). I did find a work-around that was semi-acceptable but it wouldn't allow my rafters to be shown the way I wanted them...I forget exactly what I did but I wasn't crazy about the solution.
Well...I think you can get it to work.  Not sure if this process creates other problems...but, give it a try and see what you think.
OK...so the one caveat is that this method changes the ceiling height of the room...so, may not be a good solution.
Step 1: Take a "Wall Elevation" Cameral view
Step 2: Click on the Wall
Step 3: Hit "TAB"...the selection nodes change to "small nodes"
Step 4: Drag this camera view "box" upward to reveal the entire wall.
See pics below;
Step 1:  2020-02-04_16-39-14.thumb.png.782b481eb563e97c89fbb0ddf5ab30ce.png
Step 2:2020-02-04_16-39-31.thumb.png.a8d9bd905379465eeb6836a795ef2324.png
Step 3: 2020-02-04_16-39-45.thumb.png.81e1211c38ebae8caa469bfae4308742.png
Step 4: 2020-02-04_16-44-10.thumb.png.dbeb0e0b1b0efa4f2e42814a1d87872c.png
