Eckstrom Posted September 20, 2017 Share Posted September 20, 2017 See attached pic. I'm wondering how I can apply a stone veneer to the foundation, but only above grade. I want it to slope nicely and follow the exact grade like the example I found on chief architect site. Any help would be appreciated, thanks! Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 20, 2017 Share Posted September 20, 2017 That looks like one of Joey's plans. Maybe he will see this and chime in. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 20, 2017 Share Posted September 20, 2017 You can apply-create a poly-line slab with stone as the assigned material. With this, you can control its extent and thickness. DJP Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 20, 2017 Share Posted September 20, 2017 You can also use a material region for that Link to comment Share on other sites More sharing options...
chief58 Posted September 20, 2017 Share Posted September 20, 2017 Change the foundation wall to a pony wall with the top material to what you want then in a wall detail select the foundation wall and break it where you want and adjust the walls to the grade desired Link to comment Share on other sites More sharing options...
