Mark3D Posted September 1, 2017 Share Posted September 1, 2017 Any thoughts on why the textures are looking so bad in render view second image first image is from x7 showing all is good it not just on old files it is all files with a new X9 install windows 10 machine radeon video card R9 200 Link to comment Share on other sites More sharing options...
Chopsaw Posted September 1, 2017 Share Posted September 1, 2017 Looks like maybe an incorrect Bump or Normal Map Link to comment Share on other sites More sharing options...
Mark3D Posted September 1, 2017 Author Share Posted September 1, 2017 i checked that there is no bump or normal file loaded in materials but thanks though Link to comment Share on other sites More sharing options...
Chopsaw Posted September 1, 2017 Share Posted September 1, 2017 Mark, Is that Cream Corrugated Metal because the one in my Library has a bad Bump Map Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted September 1, 2017 Share Posted September 1, 2017 I came across this when I first upgraded. There is a setting somewhere that will change that but I cannot remember where it was. Others also complained. Hopefully someone with a better memory than mine will chime in. Link to comment Share on other sites More sharing options...
rlackore Posted September 1, 2017 Share Posted September 1, 2017 Is this possibly related to Edge Smoothing while Idle? Link to comment Share on other sites More sharing options...
KirkClemons Posted September 1, 2017 Share Posted September 1, 2017 That's definitely a bump map on the texture. X7 didn't have the ability to show a bump map in standard camera views. X9 does. You said you checked 'materials' but did you check the material properties of the siding specifically? Link to comment Share on other sites More sharing options...
Mark3D Posted September 1, 2017 Author Share Posted September 1, 2017 Sorry I though I posted a reply last night to say the problem was fixed but I must have forgot to click submit it was because of that material bump plus the user had toggle texture of and he was trying to explain it over the phone so it got a bit mixed up but we got it in the end so thanks for all the kind help Link to comment Share on other sites More sharing options...
