Designer1 Posted August 26, 2017 Share Posted August 26, 2017 Hi, Im curious how others are dealing with bathroom vanity cabinet feet. I have this master bath that included two sink basins, drawers in between and at the end a full height linen cabinet all lined up right next to each other. All these cabinets have bun type feet without the normal toe kick. Automatically chief wants to just have feet at both ends and none in the middle. If you select always present on the accessories tab then each of the cabinets have their own feet shown. It seems either selection seems too much... you have either not enough feet or too many. How do other designers deal with this when the toe kick isnt present and its bun type feet that are exposed and not uniform like the regular toe kick is? Thanks! Chad Link to comment Share on other sites More sharing options...
Chopsaw Posted August 26, 2017 Share Posted August 26, 2017 Go with the four auto feet and then add another in the middle from the library and then send a note to suggestions how it should work. Link to comment Share on other sites More sharing options...
MarkMc Posted August 26, 2017 Share Posted August 26, 2017 I usually float them in one way or another-one that is easier to control is a cabinet that is 1/16 taller than the toe, with feet, cabinet material "opening no material", other cabinets are raised off the floor without toe kick. This allows the feet to get into the schedule but requires using an OIP field for the other cabinet height (depending on how it has to be ordered) Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted August 26, 2017 Share Posted August 26, 2017 As per Mark, I just delete the cabinet kick, set the cabinet bottom height off the floor to be equal to the foot height and then float and position the feet to where I want them. Link to comment Share on other sites More sharing options...
Designer1 Posted August 30, 2017 Author Share Posted August 30, 2017 Great thank you guys for the input. Its funny how chief is so relatively flexible with customization but with something as simple as the control of legs on the cabinets it appears you still have to do work arounds. I would have thought this far along with version X9 this would have been addressed. Thanks for your solutions! Chad Link to comment Share on other sites More sharing options...
sarahshuda Posted June 18, 2024 Share Posted June 18, 2024 Is this something we can do now in X15? I would love to be able to turn off feet on one side of the cabinet or the other when all cabinets butt up against one another. Can't seem to find a way to do this without this workaround yet. Link to comment Share on other sites More sharing options...
