Very new user here, so please bear with me.
Using X9 on a 64 bit Windows desktop, just recently installed.
My 'normal' drawing formats show existing walls with just two solid lines (Unfilled), demo'd walls with two dashed lines (Unfilled) and all new walls have "poche" or hatch pattern(s) within the two solid lines (filled) depending on their type.  [Typically 2D plans]
Is there any way to set up wall types or whatever to print this way? Usually plot in B/W or greyscale only, so existing wall hatch 'colors' don't help.
I don't mind if the existing walls look identical to new walls in the camera and ortho views, but for printing an existing and/or demolition plan I'd like it to show this way.
Any ideas?
Thanks
I have 2 sets of walls ,1 for new and 1 for existing. They are exactly the same except for wall fills, existing having no fill. New having a light blue fill so when printed in grayscale they come out gray. The darker the blue you make it the darker the gray fill will be.. You may also have to create new walls as you go along with special conditions.
I have always had a demo plan, where the demo'd walls have been moved to the Demo layer, which is dashed. (Fast with the Layer Painter.) Then, I have the "Proposed" plan, which shows new and existing walls, with the new walls shown by using the Wall Hatch tool. (If you have multiple patches in a long wall, I think it's better to have multiple short hatches rather than breaking up the wall into many small pieces with different wall definitions. (More stable display.) You can also  put the entire existing plan as a block on a dashed layer "below" the existing plan, so that when you remove a wall, the dashed wall lines appear.
Have you played with the "Color Off Is" setting in Preferences...Appearance...Display.
You can select ether Black and White or Greyscale.
    29813
    katienflack
    katienflack
  • Similar Content
    • By ChiefRosieRue
      I'm a relatively new user and am working my way through the Bachelor View project after the Chic Cottage project disappeared. I'm at video 6, "Creating Rooms and Defining the Ceilings" but I noticed something funky going on with some of my walls from the foundation/basement showing up on the first floor. I'm sure part of the issue is that some of my wall heights/foundation/stem walls are off, but the videos don't show what my defaults should be set to. Any advice would be greatly appreciated!
      Thank you!
    • By msshemwell
      I have two different wall types here for a basement plan I'm working on.  One is an 8" concrete stem wall with a 1 1/2" air gap, 3 1/2" framing, and 1/2" drywall.  The other is a standard interior 6 wall.  I can't seem to get them to play nice in the areas that they merge.  Any help?
    • By banditz
      currently as shown the picture i have old plan which is using metric units, then i start drawing a exterior wall, and its show me wall types (SIDING 6), but when i get a new plan & repeat drawing a exterior wall, then i dont have wall types (siding-6) ? what was wrong > i have reset everythings...
    • By KTKArch
      Anyone else experiencing strange things happening to their files "while they are closed".
      Twice that I know of now and in as many days, I have reopened a properly closed file to find significant changes happened to my file. The last things that I placed are still there, but other things have changed causing even more things to disappear. This morning's revolve around wall types changing.
      (Arrows) Level 1 walls of a specific type were replaced by 'attic' walls that are of the '8" Concrete Foundation' type from Level 0 - or with original wall type. The correct wall type, a new one I created just yesterday, is still in the system and not all of them were changed (see circled 'green filled' walls).
      Because the wall type and 'attic' change occured, the corresponding rooms were lost and any doors or windows in those walls are also gone. As are any associated dimensions.
      This also really messed up the as-built file that spawned todays Scheme 1 file. It was my only record of indoor measurements taken on-site (the first time this happened and first time I used X12 for as-built). To that end I will be printing pdf files of plans as soon as I am 'done' with as-built measurements and may consider doing as-builts in earlier versions.
      No one else has access to these files.
      X12 file from the start.
      Happened on two different PCs to the 'same' file. Second one was a Save-As of the first.
      Both times to some of the last items adjusted and typically surrounding wall types or locations.
      Note: in as-builts many things are adjusted vs newly drawn so the first time there were significant changes.
      Not just happening to 'new' wall types.
      I'm presuming it has to be something in how X12 stores or refreshes the wall types upon closing or opening.
      I will be opening a technical problem report.
    • By Draftsman-don
      I've recently purchased a new computer and installed Chief Architect 11. Everything is loaded and working except when I print I do not get any of the jpeg images. All of the line weights seem thinner than expected also. I have an HP designjet T120 printer and have downloaded the latest drivers and rebooted my computer. The printer is working properly for other software so now I'm thinking something is wrong on the Chief Architect side.  Is there a setting that I've forgotten to change or is there something I need to do to initiate a new printer driver? Any help is appreciated.
