Marina_R Posted July 12, 2017 Share Posted July 12, 2017 Why do my elevations turn out blurry and some lines missing when I send them to layout? What can I do to prevent that? Link to comment Share on other sites More sharing options...
Kahnceptions Posted July 12, 2017 Share Posted July 12, 2017 For the view you are sending to the layout, there is a dialogue box that pops up. Look under "Scaling" Make sure the "use layout line scaling" is unchecked. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 12, 2017 Share Posted July 12, 2017 23 minutes ago, Marina_R said: Why do my elevations turn out blurry and some lines missing when I send them to layout? What can I do to prevent that? When you go to print from layout it will show properly, chief does this to save computer resources...you can also update the view with the spinning wheel(Update view) in the bottom tool bar when you select the view 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted July 12, 2017 Share Posted July 12, 2017 4 minutes ago, Renerabbitt said: When you go to print from layout it will show properly, chief does this to save computer resources... ...yes but there is no way any user would know this as Chief doesn't tell anyone about this 'feature' so your (OP) confusion is understandable. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 12, 2017 Share Posted July 12, 2017 If you want them to be sharp in layout you can zoom way way in and select the layout box and hit refresh as this seems to be dependent on current screen resolution and magnification. Just be aware this will use resources to display this way and may slow things down on you. 1 Link to comment Share on other sites More sharing options...
Marina_R Posted July 12, 2017 Author Share Posted July 12, 2017 @Renerabbitt ye it does however some lines are still missing when I send to print.. Some days when I send to layout, it shows perfectly with the right line weights and all cad lines shown ( these are my lucky days) however most of the time it shows blurry elevations and missing lines. Frustrating. Link to comment Share on other sites More sharing options...
Dermot Posted July 12, 2017 Share Posted July 12, 2017 See if this knowledge base article helps. If not, I would recommend that you contact tech support. https://www.chiefarchitect.com/support/article/KB-03064/live-views-on-layout-appear-blurry.html Link to comment Share on other sites More sharing options...
Dermot Posted July 13, 2017 Share Posted July 13, 2017 Quote ...yes but there is no way any user would know this as Chief doesn't tell anyone about this 'feature' It's really not a feature but it is something we have to deal with because of technical limitations related to producing high resolution camera views in real time. It's also not some big secret we are trying to hide. There is a whole section in the Reference Manual about "Keeping Layout Views Current" where this issue is mentioned. There is also the help article that I posted above. Link to comment Share on other sites More sharing options...
Marina_R Posted July 13, 2017 Author Share Posted July 13, 2017 @Dermot OOOH thanks. I usually go straight to articles when I have issues, but didn't think they would have an article on this. Thought it was just me having this issue. Wasn't aware it was an "option" introduced in X8 and so forth. Thanks. Link to comment Share on other sites More sharing options...
