Ronniego
Need Guidance Fixing Roof Line
Greeting!
I am relatively new to Chief Architect, okay a newbie. I am attempting to draw a floor plan but am have a major problem with the roof line.
The 'valley' in the garage area594196dc68a00_RoofValley.thumb.jpg.b1cafb09365cc9e799db6f80ff3bd248.jpg
causes the roof line to not come straight across. 594196cf6e3bd_UnevenRoofLine.thumb.jpg.c8e68580ef3dbf5c077710a8cb80898f.jpg
I have tried & tried to fix this and looked at almost all of the roof tutorial videos. If someone would provide some guidance, I would really appreciate it.
Attached is the plan
Ronniego Floor Plan.zip
I have purchased X9
Using windows 10
 Thank you!!
Suz
(aka Ronniego)
My version.
Roofs take practice, and more practice for many.
Consider drawing practice plans developing different type of roofs, using the automatic and manual roof tools.
Give D.J.P. a point, he fixed your problem!!!!! D.J.P. helps many.
Click the green up arrow over on the right side to give someone a point
DJP is a Texan,  but we do not hold that against  him,  he is a good guy.
    27448
    dan_heidel
    dan_heidel
  • Similar Content
    • By 9atatimer
      I'm using X11 premier on a mac -- I have an exterior garage wall (with a centered garage door) and a gable end -- I'd like to split the attic wall of the gable end into 3 parts -- the central region above the garage door, and the left and right, to have a different material above the garage door.
      I have Default Settings > Roof > Auto Rebuild Roof set to Off
      I have Default Settings > Framing > Automatically Build Floor and Ceiling Framing Off on all framing types.
      I have Default Settings > Walls > General Walls > Auto Rebuild Attic Walls set to Off
      If I delete the roof and ceiling planes with Build > Roof > Delete [X] and then use the Build > Roof > Build Roof ... dialog to rebuild the roof and attic from scratch -- I leave the Auto Rebuild Roofs set to Off, to be clear -- and then edit the resulting gable roof on the attic layer, I can split it twice to produce the three separate wall sections, but once I change the exterior material on any of the sections, the three wall segments get replaced with a single wall again.  The new wall has my selected material, but that does me no good as I need the distinct secgments.
      Anyone know what setting do I need to turn off to maintain the manually edited gable end?  Or is this a mac bug?
      Or, barring that, does anyone know what approach will let me give the desired finish detail (attached a pic of a freehand elevation)?
    • By blueriver
      I'm using Chief Architect Premier X11
      I have all these little 'X's can someone please tell me how to get rid of them?  I've been really playing around with the roof and i THINK they are from that but at the same time i have a couple random ones outside where the roof is -- i cannot get them to go away. Help!
      thanks in advance
      Lauren
    • By chief69
      Hello, We are having a hard time getting  the design program to do the roof right. We have tried with Sketchup and it got the closest. It's hard to describe I have attached a few pics with a decent idea of what we are trying to do.
      The Garage is a shed roof as well as the breeze way, but they are at different angles. The house is a butterfly style with the V running at a angle. WE do not care what the pitch ends up being on any of the roofs.
      Anyone know how to do this. I have been trying for hours and the program goes crazy every time. Esp with the all 3 roofs at different angles with each other. I have attached a copy of the plan we made and some pics from sketchup because that program got the closest to what we are trying to do.
      Thanks
      Chris
      New house v1.plan
    • By MN_JohnH
      I wonder why my second floor loft flooring is sticking through the roof and can be seen on the outside of the building?
    • By mprovost129
      Hi all. I'm fairly new to the software and have only been using it since October. I have a client who wants a wood framed chimney extruding from the middle of the roof up from the gas fireplace. I've tried a bunch of different options to make this work but can't figure it out. Can someone please tell me how to draw walls on top of the roof?
      Thank you!
