framing exposed at bottom of open below wall
Larry_Sweeney
Get real comfortable using molding polylines and p-solids to cover up these and many more issues in Chief.
I had a plan once that, I swear, would've been quicker to build entirely out of soffits or cabinets instead of walls/floors/roofs.
I'm exaggerating only slightly.
Larry, as Michael has suggested some work-rounds may have to be applied to get a more perfect look in camera views. Another "solution" is to set all framing to carry "Drywall" as its material instead of the default wood material. I just do what I must to quickly get an acceptable appearance to what I am doing.
Sorry I didn't get back to this earlier. I manually moved the wall down and then back to it's original position and drywall showed up on the bottom of the framing. I guess this would be considered a "work around"--------------- go figure.  ;)  Thanks to all for your time and advice. Have a great day.
