abovethewave Posted April 13, 2017 Share Posted April 13, 2017 I recently used the Reverse Plan feature in Chief and got a strange anomaly with the roof. On one of the ridges (that runs front to back of the house, the roof lines appear to extend past the ridge. I almost appear as though the ridge cap is upside down. I can't seem to find a way to fix this. Hoping someone can take a look. I need to create renderings for an MLS listing. Thanks! Rancher_(030)_v01.plan Link to comment Share on other sites More sharing options...
Griffin Posted April 13, 2017 Share Posted April 13, 2017 Try this: Unlock your ridge cap layer and delete it. Then add it back if you need it for your rendering. Link to comment Share on other sites More sharing options...
abovethewave Posted April 13, 2017 Author Share Posted April 13, 2017 Thanks for the advice. It's somewhat lost on me as I am not sure that is the problem. I attempted that, but it appears to be local to the roof planes - as far as I can tell. Link to comment Share on other sites More sharing options...
ShaneK Posted April 13, 2017 Share Posted April 13, 2017 Post your plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 13, 2017 Share Posted April 13, 2017 I opened the plan and I don't see any problem with the roof planes. I tried it using Reverse Plan... And I tried using Edit Area... What am I missing? Nice looking work by the way. EDIT: Now I see what you were talking about. I missed the upside ridge cap in the original plan orientation as you posted it. Not too difficult to fix as some of the other guys have mentioned (both above and in posts below) but please report this to tech support as a bug so that it gets fixed. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted April 14, 2017 Share Posted April 14, 2017 I had a quick play with this. Very strange. I can confirm that it is in fact an inverted ridge cap, but I can't determine what is generating it. I deleted all the roof planes and everything on the Attic level and the inverted ridge cap remained. If you only need to render the view you can do as Griffin suggests and turn off the layer. You will lose all the ridge caps in the view but with the dark color you are using for the roof the lack of ridge caps is not readily apparent. However I found that restoring the ridge caps resulted in the inverted and unwanted cap returning. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 14, 2017 Share Posted April 14, 2017 here is your fixed plan, you had some roof plane baselines that were off just a tad. Rancher_(030)_v01_fixed.plan Link to comment Share on other sites More sharing options...
