Follow the Leader
lbuttery
when I moved the rear fence from 96' to 48' the dims stayed where they were
it would be nice if they moved and maintained their relationship with the fence
kinda looks silly with those super long extension lines
is there a way to control this or should I make a suggestion for this issue ???
I know how to move them - but I shouldn't have to do that
Lew
216_UPCHURCH_MODEL_170405_2155_LBX8.zip
Lew,
I am not sure what you did wrong, but Michael gave you the correct answer.
It also works on multiple stacked dimension lines.
On ‎6‎/‎04‎/‎2017 at 3:52 PM, lbuttery said:
ok, I just checked the manual and that only works for ONE line
This applies to one extension line, not one dimension line.
You only need to set the Proximity Fixed setting for 1 extension line.
my suggestion is that the dims should auto-magically follow when the object is moved
And this is exactly what happens.
https://www.screencast.com/t/ix08yNnAxE5
