Joe_Carrick Posted February 27, 2014 Share Posted February 27, 2014 I selected a Material Region to Edit - Then Selected EDIT When I subsequently selected Plan Material Chief hung up - nothing was selectable. ESC got me out but if I tried to open another window such as Chieftalk before hitting ESC then I couldn't do anything and had to use Task Manager to close Chief. See the attached pic. It just seems like a total "disable" of the window. Maybe there was an underlying window that I couldn't see. Link to comment Share on other sites More sharing options...
glennw Posted February 27, 2014 Share Posted February 27, 2014 Joe, All working here OK. I can't duplicate your problem. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 27, 2014 Author Share Posted February 27, 2014 Glenn, Did you try it on a Floor Material Region - recessed? Link to comment Share on other sites More sharing options...
Solution Dan_Park Posted February 27, 2014 Solution Share Posted February 27, 2014 It does sound like a window that did not display. ESC would get you out of that. Do you have more than one monitor? Link to comment Share on other sites More sharing options...
glennw Posted February 27, 2014 Share Posted February 27, 2014 Glenn, Did you try it on a Floor Material Region - recessed? Joe, If you mean Cut Finish Layers....yes that was checked - no problems. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 27, 2014 Author Share Posted February 27, 2014 It does sound like a window that did not display. ESC would get you out of that. Do you have more than one monitor? Of course that was it. One of the monitors was turned off. That's where the extra window was. Link to comment Share on other sites More sharing options...
Doggies1954 Posted February 27, 2014 Share Posted February 27, 2014 Silly Joe. 1 Link to comment Share on other sites More sharing options...
