Sign in to follow this
Joe_Carrick
Chief X6 Hangs Up
I selected a Material Region to Edit - Then Selected EDIT
When I subsequently selected Plan Material Chief hung up - nothing was selectable.  ESC got me out but if I tried to open another window such as Chieftalk before hitting ESC then I couldn't do anything and had to use Task Manager to close Chief.
See the attached pic.  It just seems like a total "disable" of the window.  Maybe there was an underlying window that I couldn't see.
Joe,
All working here OK.
I can't duplicate your problem.
It does sound like a window that did not display. ESC would get you out of that. Do you have more than one monitor?
Glenn,
Did you try it on a Floor Material Region - recessed?
Joe,
If you mean Cut Finish Layers....yes that was checked - no problems.
Of course that was it.  One of the monitors was turned off.  That's where the extra window was.
    27645
    ChiefUserTyMN
    ChiefUserTyMN
