BlackDiamond Posted March 18, 2017 Share Posted March 18, 2017 I am using X9 and have either inadvertently deleted the level title and area calc or it wasn't there to begin with. I've tried unchecking it in the plan defaults, clicking ok, then re-opening it and re-checking it. I've tried re-starting CA. I've also tried the plan check in tools. Nothing brings it back. Any suggestions? Thanks Link to comment Share on other sites More sharing options...
justmejerry Posted March 18, 2017 Share Posted March 18, 2017 Check if room labels layer is on. Link to comment Share on other sites More sharing options...
glennw Posted March 18, 2017 Share Posted March 18, 2017 Do you have a room definition on level 0? Link to comment Share on other sites More sharing options...
BlackDiamond Posted March 18, 2017 Author Share Posted March 18, 2017 Yes... I have a floor plan drawn and the rooms are labeled. I've also turned on the room interior area layer so that I can estimate what the total sf is. Link to comment Share on other sites More sharing options...
lbuttery Posted March 18, 2017 Share Posted March 18, 2017 click on each room and verify you have room definition in all of them also post the plan so you get more than quesses if no solution by Monday you may need to send to tech support ? Lew Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 18, 2017 Share Posted March 18, 2017 Run a plan check...Tools>Checks>Plan Check. See if that brings it back. Link to comment Share on other sites More sharing options...
lbuttery Posted March 18, 2017 Share Posted March 18, 2017 Michael: she already tried that ... Lew Link to comment Share on other sites More sharing options...
BlackDiamond Posted March 19, 2017 Author Share Posted March 19, 2017 Now it's not showing up on the main level either. Hmmmmm In the past, I've always just started with a previous plan and deleted all content to start a new project. But we appear to be having crash issues when editing sections from plans created in X8 in X9. So... with this one, I started fresh with a new plan in X9 and tried to re-create all our defaults. I've attached the preliminary plan that's having the issue. Thanks Chumley.plan Link to comment Share on other sites More sharing options...
BlackDiamond Posted March 19, 2017 Author Share Posted March 19, 2017 Thanks Eric... that worked. Not sure what happened! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 19, 2017 Share Posted March 19, 2017 I only looked at the plan just briefly but a couple quick observations… Running a plan check brings the label back on the first floor. The foundation though is a little unique. I'm not positive WHY but the label on that level is a little more stubborn. If you enclose a new room off to the side on that level you will get a living area level for that room however getting the living area label for the existing area back seems to be a different story. There maybe other methods that will bring it back but using Eric's suggested method seems to do the trick. No need to paste it into another plan though. You can paste it right back into that same plan and the living area label returns. Link to comment Share on other sites More sharing options...
BlackDiamond Posted March 20, 2017 Author Share Posted March 20, 2017 Thanks Michael. I don't know why I didn't think of copying/pasting it! I tried every thing else. I guess that's what this forum is for... LOL Link to comment Share on other sites More sharing options...
glennw Posted March 22, 2017 Share Posted March 22, 2017 The problem on level 1 is being caused by the external wall between the Porch and the Great Room. The wall is reversed. Select it, click Reverse Layers and then Plan Check. The Living Area label should display. The wall to the right of the Porch is also reversed - but doesn't appear to be contributing to the problem. I haven't had time to have a good look at level 0. Although most, if not all of the rooms are specified as Exclude From Total Living Area Calculation. Link to comment Share on other sites More sharing options...
