BlackDiamond Posted March 10, 2017 Share Posted March 10, 2017 I am creating wall views for the interior designer and using the 'wall elevation' command under 3D. However it always shows a flat ceiling and doesn't show any vaults. Is there a way to accurately show the full gabled wall? Link to comment Share on other sites More sharing options...
Kenoeightspot Posted March 10, 2017 Share Posted March 10, 2017 Use a cross section view then mask around what you do not want to see. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 11, 2017 Share Posted March 11, 2017 On 3/10/2017 at 11:25 AM, Kenoeightspot said: Use a cross section view then mask around what you do not want to see. Yep. This is what I do as well. I pretty much never use the wall elevation tool. It really has more limitations than benefits IMO. Link to comment Share on other sites More sharing options...
johnny Posted March 12, 2017 Share Posted March 12, 2017 I agree with everyone on current fix, but the OP has a point about a need for a faster way to get interior wall sections to mask correctly. The way Chief currently does interior wall elevations isn't how the industry typically shows those drawings. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 12, 2017 Share Posted March 12, 2017 If you balloon frame that wall it will show the vault in a wall elevation view. That is how it would be built in real life. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 12, 2017 Share Posted March 12, 2017 Don't know, looks like it did give the vault to me, I must not understand what you are asking, maybe framing is turned off in that wall elevation Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 13, 2017 Share Posted March 13, 2017 so doesn't your view show it, looks like it to me. Link to comment Share on other sites More sharing options...
