Kenneth_Miller Posted February 23, 2017 Share Posted February 23, 2017 TO all, Any advise as to why this is happening? See attached. I don't want a boxed eave but can't get the frieze boards to connect. Thank you in advance. Link to comment Share on other sites More sharing options...
Evolution Posted February 23, 2017 Share Posted February 23, 2017 KM, it may be something simple, but I haven't had that issue before. The CA-guru's on the forum may just pop the answer out without further-a-do, however some might respond that if you'd post the plan it might be quicker / easier to get the answer.? Also, if you use this Forum much it will be good if you go to your signature, and add the software you are currently using, just a thought Link to comment Share on other sites More sharing options...
Griffin Posted February 23, 2017 Share Posted February 23, 2017 You might try adding a corner board to see what happens. BUILD>TRIM>CORNER BOARDS Link to comment Share on other sites More sharing options...
Kenneth_Miller Posted February 23, 2017 Author Share Posted February 23, 2017 Griffin, Didn't work, Thanks for the idea. Link to comment Share on other sites More sharing options...
javatom Posted February 23, 2017 Share Posted February 23, 2017 This is also a guess. Maybe the eaves and gable end to not match. Make sure they snap to each other. Link to comment Share on other sites More sharing options...
Kenneth_Miller Posted February 24, 2017 Author Share Posted February 24, 2017 To all, Attached is the plan file for this issue. Thank you all in advance. Freize Board issue.plan Link to comment Share on other sites More sharing options...
javatom Posted February 24, 2017 Share Posted February 24, 2017 open the dbx for the main roof go to "options" and uncheck boxed eave. Link to comment Share on other sites More sharing options...
javatom Posted February 24, 2017 Share Posted February 24, 2017 You also have a problem on the roof plane on the right side. Make it have the same fascia height and it will look right (keep pitch locked). Link to comment Share on other sites More sharing options...
javatom Posted February 24, 2017 Share Posted February 24, 2017 Your also using a roof plane as a ceiling plane. There is a separate tool for ceiling planes. Link to comment Share on other sites More sharing options...
Kenneth_Miller Posted February 24, 2017 Author Share Posted February 24, 2017 To all, Thank you all for your replies. Unfortunately I can not get any of these to work. Also, it will not let me mull the half round and doors. Attached is the plan file for this issue. Thank you all in advance. Freize Board issue.plan Link to comment Share on other sites More sharing options...
Kenneth_Miller Posted February 24, 2017 Author Share Posted February 24, 2017 solver, I auto built the hip roof and it works fine but when I add the front gable, the frieze boards detach. The front walls are Ballon Through Ceiling Above. See screenshot. Link to comment Share on other sites More sharing options...
AlwaysEastern Posted February 24, 2017 Share Posted February 24, 2017 I have had that happen to me before. I sent to Chief Jan 2016. There was no solution. Here is a portion of their response "I will report this to our developers so that they are aware of the issue, and maybe they can fix it in a future update/release." Link to comment Share on other sites More sharing options...
AlwaysEastern Posted February 24, 2017 Share Posted February 24, 2017 Eric, I was actually able to get it to work by ballooning just as you stated. My original problem had boxed eaves and a crown molding below on gables and eaves. Chief support stated: "I tried this in X7 and it did the same thing. The issue seems to be specific to the boxed eaves. I believe the program is not mitering the eaves correctly." Link to comment Share on other sites More sharing options...
Kenneth_Miller Posted February 24, 2017 Author Share Posted February 24, 2017 To all, Still struggling with it but may just need to update to X9. If I don't use boxed eaves the soffit is sloped and I don't see the frieze board. I'll keep trying. Thank you, Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 24, 2017 Share Posted February 24, 2017 Here's a quick video with a workaround you can use when no other solution seems to fix the problem. In short though...unlock the roof trim layer and manually modify the molding... 2 Link to comment Share on other sites More sharing options...
javatom Posted February 24, 2017 Share Posted February 24, 2017 Unlocking the trim and adjusting it gets mixed results and if you have to snap that roof plane to a new element it will generate another frieze board with the same problem. If you're going to go manual, it is faster to create a p solid and turn the frieze off for the roof planes in question. Link to comment Share on other sites More sharing options...
yusuf-333 Posted February 25, 2017 Share Posted February 25, 2017 I am with Michael here, if you once detach the freeze board manually as Michael has shown, then you don't need the auto generated one, so you should select roof planes and in their dbxs you are able to remove the auto generated freeze boards for good. Link to comment Share on other sites More sharing options...
javatom Posted February 25, 2017 Share Posted February 25, 2017 That's a good tip. It will not regenerate again if it is shut off. Link to comment Share on other sites More sharing options...
