Split high panel wall
Lewdis
I have built a house with panel and now I would like to make a break in the panel so that it doesn't look like I have 5 meter high panel on the wall.
I have attached an example of that I would like to do. As you see the upper panel is in front of the lower.
53602076815c3225d9ecb67f9adb0561127b8c5a
Not sure if this will work, but I would build the wall as a pony wall, set the height of the lower portion to your desired height, then select the upper portion change the thickness of the wall (Not sure if changing the upper thickness is possible without affecting the lower portion?) to push the finished siding layer out whatever thickness the siding adds. Give it a try and see if that works.
Shoot a Cross Section / Elevation, create a CAD Detail from View, then create a Closed Polyline the shape of the gable element, copy/paste-hold it into the Cross Section / Elevation, then Convert Polyline to a Material Region that doesn't cut the finish.
