Pass through in corner on angle. How?
AlexZan
4 minutes ago, Kenoeightspot said:
Two "Pass " thru windows with casings & sill turned off. Sill at floor level "0"
Place on separate layer and turned off in plan view.
Thank you, that works at 90°, but does it work at 45°? I don't think it does
Sill at "0" see below.
Also this works with three walls but framing at header will need adjusting.
And to move them into the corner position do u just drag them to the corner? I can do that with the on on the right, but the left one will not snap
46 minutes ago, Kenoeightspot said:
You need to throw them both past the corner.
Thank you. Is there any trick to this? I seem to get either one or the other to snap to the corner, but not both. I just realized that it might not be exactly 45° but maybe a bit off, would that affect it?
30 minutes ago, MarkMc said:
I pasted the pass through in-the problem is where it meets the other wall, used a psolid for that. Don't think there is another way around that. Then made room molding polyline.
Wow that looks great! Any more detail on how you did that? I will try to replicate it. Thank you! Is the pillar a psolid?
