tommy1 Posted February 8, 2017 Share Posted February 8, 2017 I anyone getting shadows in the corners when doing renders in X9? I don't get this in X8 or earlier. See attachments. Link to comment Share on other sites More sharing options...
dshall Posted February 8, 2017 Share Posted February 8, 2017 Yes, it is an added feature in X9. I think there was a thread earlier that suggested a way to eliminate the shadow.... I like the shadow. Link to comment Share on other sites More sharing options...
tommy1 Posted February 8, 2017 Author Share Posted February 8, 2017 Thanks, I'll look again but didn't fine anything. Link to comment Share on other sites More sharing options...
kMoquin Posted February 8, 2017 Share Posted February 8, 2017 In General Camera Defaults, enter a lower number for Ambient Occlusion to lessen the effect, or zero to eliminate. Link to comment Share on other sites More sharing options...
tommy1 Posted February 8, 2017 Author Share Posted February 8, 2017 2 minutes ago, kMoquin said: In General Camera Defaults, enter a lower number for Ambient Occlusion to lessen the effect, or zero to eliminate. I'll try that too. Turning off "enhanced lighting" definitely fixed it though. Link to comment Share on other sites More sharing options...
tommy1 Posted February 8, 2017 Author Share Posted February 8, 2017 Thanks Kevin, that works. I think I'll keep enhanced lighting turned on and set the Ambient Occlusion set to zero. Not sure what the difference is. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 8, 2017 Share Posted February 8, 2017 31 minutes ago, tommy1 said: I'll try that too. Turning off "enhanced lighting" definitely fixed it though. As I understand it the Enhanced Lighting toggle is simply a video card troubleshooting tool and SHOULD NOT be toggled off under normal circumstances. The correct way to control that shadow effect is by adjusting your ambient occlusion settings as Kevin suggested. Turning off Enhanced Lighting is going to have other unwelcome side effects. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 8, 2017 Share Posted February 8, 2017 2 minutes ago, Alaskan_Son said: As I understand it the Enhanced Lighting toggle is simply a video card troubleshooting tool and SHOULD NOT be toggled off under normal circumstances. The correct way to control that shadow effect is by adjusting your ambient occlusion settings as Kevin suggested. Turning off Enhanced Lighting is going to have other unwelcome side effects. Yes I think Dermot said this. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 8, 2017 Share Posted February 8, 2017 5 minutes ago, DRAWZILLA said: Yes I think Dermot said this. Yep. Plus, that toggle is located under a subsection called "Troubleshooting". Here's what it says in the Help file... The Troubleshooting settings can be used to troubleshoot performance in 3D views. • When Use Enhanced Lighting is checked, Standard rendered views generate lighting effects that require a video card that supports OpenGL 2.0. Unchecking this box may speed up Standard rendering times somewhat; however, the quality of lighting effects will be reduced. Not available if your video card does not support OpenGL 2.0. See OpenGL and Hardware. • Software Rendered Overlays helps address specific errors that can occur with certain video cards and is checked by default. In some rare instances, this may slow rendering time somewhat. Note that it will become checked automatically if the program encounters certain error conditions. • Command Flushing - Select an option from the drop-down list to control how often the program flushes cached video memory. “Rarely” is selected by default and will produce fastest rendering times on most systems, but “Frequently” may be helpful for older video cards. Link to comment Share on other sites More sharing options...
tommy1 Posted February 8, 2017 Author Share Posted February 8, 2017 It sounds like I have everything set right. Link to comment Share on other sites More sharing options...
