light bleed in raytrace
MAINEWOOD59
I'm not seeing any bleeding issues. I opened your
plan but didn't see any saved interior camera views
so I just took a Full Camera view of the cabinets and
ran a High Quality Indoor Ray Trace. Can you post
the troublesome camera view or perhaps the problem
image and the settings you are using?
Already have a roof on it.  I posted the plan if anyone wants to take a look?
Thanks
4 hours ago, TheKitchenAbode said:
Try setting the Ambient Occlusion Min=0, Max=3 and uncheck "Use Camera View Settings". Here's what I get with these settings. You can use the Image Properties settings to adjust contrast, intensity, etc.
Graham
Here is my raytrace with your settings.  Much better.  I will experiment with the image properties...
Thanks!
Pleased that those settings got things under control. The Image Properties settings I used on my posted pic are here below.
Contrast - 83
Intensity - 36
Softness - 0
Color Correction - 0
Brightness - 48
Contrast - 62
Saturation - 50
Here is one with some additional lights added in, things seem to be working as I would expect. Would need more work but at least heading in the right direction.
Graham
Mainwood59 - Was able to recreate the issue, pic below. When in the camera view and if in the Active Layer Display options the Roof Planes are turned off you will get this effect. If you turn the sun off then this effect will go away but will come back if you turn the sun back on. Check to make sure that the Roof Planes are turned on in the Layer Display options.
Graham
