phil1322 Posted June 11, 2014 Share Posted June 11, 2014 Hello everyone, I was just wondering if anyone out there has ever done a roof similar to this picture below, is it/would it be easy to achieve in Chief?? Phil Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 11, 2014 Share Posted June 11, 2014 I don't think you can do it automatically but ,yes ,I have done some of those Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 11, 2014 Share Posted June 11, 2014 Easy is a rather subjective term, I have done mansard roofs but manually, I suppose you could get kinda-sorta close automatically with a lot of presetting but would then envolve some manual editing afterwards. DJP Link to comment Share on other sites More sharing options...
lbuttery Posted June 11, 2014 Share Posted June 11, 2014 David: a basic Mansard can be done with just a few settings for the auto-roof gen see the "styles" tab on the roofs dbx or the roof vidoes or help articles there are over 24 different roof styles and/or complex roofs that can be done with the auto roof gen CA recommends to start with auto then go manual if/as needed Lew Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 11, 2014 Share Posted June 11, 2014 Come on, Lew, really. The roof the OP wants is not the same as what chief has, manual for sure Link to comment Share on other sites More sharing options...
ebdesign Posted June 11, 2014 Share Posted June 11, 2014 This is automatic w/ the roof break to flat (actually 1/4" slope) defined in the walls. And a barrel dormer added too. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 11, 2014 Share Posted June 11, 2014 Still not the same roof, looks like a parapet wall to roof Link to comment Share on other sites More sharing options...
lbuttery Posted June 11, 2014 Share Posted June 11, 2014 Perry: so what is different ??? Jim's solution looks like the OP's request to me ??? If not, I'm sure it could be tweaked manually just don't see a need to start manual and ignore the auto-gen have you tried the Mansard auto-gen settings ??? Lew Link to comment Share on other sites More sharing options...
GerryT Posted June 11, 2014 Share Posted June 11, 2014 Hmmm -- After all walls are drawn - Select all walls and open DBX -- Set Lower pitch as required (>12), upper pitch at 1/4" & setback from baseline. Build Roof -- Time less than a minute. Always start with the Auto. Link to comment Share on other sites More sharing options...
ebdesign Posted June 11, 2014 Share Posted June 11, 2014 You mean something like this Perry? I haven't drawn a manual roof plane in months...........maybe longer. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 11, 2014 Share Posted June 11, 2014 Similar, except the parapet wall extends higher than the roof. I can never get the auto roofs to do what I need, I do start with auto roofs but must always fix them unless they are very simple. Link to comment Share on other sites More sharing options...
