Korel_Design Posted December 11, 2016 Share Posted December 11, 2016 Hello All, How do you create print quality or web quality graphics of your floor plans? I tried the File>Export>Export Picture (BMP,JPG,PNG....). I preferred the uncompressed TIFF files before I load them into PhotoShop. The export is totally not acceptable. Very low resolution. I even tried a screen capture using Snipit. That was better than CA's Export but still not the quality I am use to. Or.... If I could export a HPGL2 PLT file. I have software that I use with that other CAD program that I use to create my web graphics. Thanks, JK Link to comment Share on other sites More sharing options...
Chopsaw Posted December 11, 2016 Share Posted December 11, 2016 Jerry, Are you wanting to generate high resolution files from plan view without sending to layout? Because you can print to PDF and using the "Chief Architect Save As PDF" you have options all the way up to 4000 dpi. which should be overkill for most print situations. You end up with an excellent quality vector PDF file. This also works for 3D views by using File>Print>Print Image. I use this for another application where I need high res. Link to comment Share on other sites More sharing options...
Electromen Posted December 11, 2016 Share Posted December 11, 2016 Print to PDF and make sure your PDF Printer is using Vector images. .Tif, jpeg, .bmp are raster based images using pixels. Vector uses solid lines, not pixels Link to comment Share on other sites More sharing options...
Korel_Design Posted December 11, 2016 Author Share Posted December 11, 2016 Tnx for your reply. What I wound up doing was Save As PDF as you suggested, then convert the PDF to a raster file in either PS or my printer software. KIP Request has a utility to create a Hi Rez raster image. I just figured the "File>Export>Export Picture (BMP,JPG,PNG....)" could create a Hi Rez PNG so I can use it on my website without having to juggle the image through several utilities such as I do. Tnx, JK Link to comment Share on other sites More sharing options...
Korel_Design Posted December 11, 2016 Author Share Posted December 11, 2016 Thank you Greg. I know all about Vector Images and Pixel (Raster) Images. The final file needs to be something I could display on a website. At least 256 colors and about 1200 pixels wide x 800 pixels tall. Either a GIF or PNG. I use JPG on all my renderings and photographs. Apparently, Chief Architect can not provide a direct output of such a file. (hint hint). Maybe it's there I just haven't found it yet. JK Link to comment Share on other sites More sharing options...
Electromen Posted December 11, 2016 Share Posted December 11, 2016 1. In CA, Print to .PDF 2. Open in Photoshop 3. PS will convert it to raster, 300 PPI (DPI) is high enough 4. File > Save for Web & Devices 5. Message about file size > YES 6. Preset > PNG-24 7. Check or uncheck Transparency, this is the background 8. Image Size > Input the size you want 9. Metadata > Copyright 10. Convert to sRGB > Check 11. Quality > Bicubic Sharper 12. Save You now have a .PNG image Link to comment Share on other sites More sharing options...
Electromen Posted December 11, 2016 Share Posted December 11, 2016 Try This: In CA 1. Turn off Reference Grid if it's on > View > Reference Grid 2. File > Export > Export Picture 3. Resolution = 600 > OK 4. At the bottom select PNG Files (*.PNG) 5. Save Link to comment Share on other sites More sharing options...
Korel_Design Posted December 11, 2016 Author Share Posted December 11, 2016 Sounds good. JK Link to comment Share on other sites More sharing options...
johnny Posted December 11, 2016 Share Posted December 11, 2016 I think the OP has found an area where Chief is broken. I've used multiple settings with virtually no change in what gets exported. This can't be working correctly so should be reported as bug based on my tests that confirm what the OP is experiencing. Link to comment Share on other sites More sharing options...
Korel_Design Posted December 12, 2016 Author Share Posted December 12, 2016 2 hours ago, Electromen said: Try This: In CA 1. Turn off Reference Grid if it's on > View > Reference Grid 2. File > Export > Export Picture 3. Resolution = 600 > OK 4. At the bottom select PNG Files (*.PNG) 5. Save I tried this Greg.... The image is very blurry and not very good resolution at all. Very Blurry. Until the programmers at CA can give me a button to click, I will print/save as a PDF then load that into PS to convert to a PNG I can use. Thanks for your help. JK Link to comment Share on other sites More sharing options...
Chopsaw Posted December 12, 2016 Share Posted December 12, 2016 1 hour ago, johnny said: I think the OP has found an area where Chief is broken. I've used multiple settings with virtually no change in what gets exported. This can't be working correctly so should be reported as bug based on my tests that confirm what the OP is experiencing. Yes CA has been aware of this for quit some time but I am not sure they have done anything about it, so it would not hurt to remind them repeatedly especially when they provide a DBX with adjustments that are clearly labeled yet do nothing !!! 40 minutes ago, Korel_Design said: I tried this Greg.... The image is very blurry and not very good resolution at all. Very Blurry. It seems that for now all you get is basic screen resolution regardless of the settings which in theory should be ok for use on a website as long as no quality is lost along the way. Link to comment Share on other sites More sharing options...
Korel_Design Posted December 12, 2016 Author Share Posted December 12, 2016 Here is a better way. File>Export>Export Meta File EMF... Then open in Paint, Save as PNG. A much better PNG than what CA Exports. If it's a little fuzzy, I open in Topaz Labs InFocus and make it very sharp. Hopefully, X9 will have a better image export. Tnx, JK 17 hours ago, Electromen said: Link to comment Share on other sites More sharing options...
joey_martin Posted December 12, 2016 Share Posted December 12, 2016 I simply export as jpeg from my plan view screen. I post these to the net all the time, never seem to have an issue. Link to comment Share on other sites More sharing options...
Korel_Design Posted December 15, 2016 Author Share Posted December 15, 2016 That looks very good. I will try that. Thanks. JK Link to comment Share on other sites More sharing options...
