HumbleChief Posted November 28, 2016 Share Posted November 28, 2016 I've got a couple of windows that span vertically both the first and second floor but only display on the floor they were drawn on. Is there a way to get them to display on both the floor they were drawn on and the floor above and or below? (yes there are structural concerns but I'd like to get the floor plans correct for the contractor's review.) Here's a 3D shot below is the second floor ..and the first floor. Neither floor showing the windows on both floors they span. Link to comment Share on other sites More sharing options...
rlackore Posted November 28, 2016 Share Posted November 28, 2016 I copy the window, move to the second floor, then paste in place. Position it the same as the first floor window (using the absolute elevation as the reference height makes this easy). If you want you can put the second floor window on its own layer so it can be hidden in 3D views, but I find this isn't usually necessary. Link to comment Share on other sites More sharing options...
BrownTiger Posted November 28, 2016 Share Posted November 28, 2016 YES and uncheck "include in schedule" for a second copy. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 28, 2016 Author Share Posted November 28, 2016 THANKS, I'll get to it shortly. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 28, 2016 Author Share Posted November 28, 2016 Worked a treat. Thanks again. Link to comment Share on other sites More sharing options...
javatom Posted November 28, 2016 Share Posted November 28, 2016 You might want to check the top of window settings for the two corner windows. They look different but maybe its just how the cam view is displaying it. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 28, 2016 Author Share Posted November 28, 2016 On 11/28/2016 at 7:10 PM, javatom said: You might want to check the top of window settings for the two corner windows. They look different but maybe its just how the cam view is displaying it. Expand Lots of tweaking left to go, but thanks for the tip. Link to comment Share on other sites More sharing options...
johnny Posted November 28, 2016 Share Posted November 28, 2016 This is an interesting thread. Anytime i have two windows in the same location I get odd glitches in the wall - sometimes on the interior and sometimes on the exterior. You guys dont get that? This is actually an issue I run into often and end up just having to place a note on the floor plan that doesn't show the window. Perhaps an option to see a window on different floors should be a suggestion? Link to comment Share on other sites More sharing options...
BrownTiger Posted November 28, 2016 Share Posted November 28, 2016 @ Anytime i have two windows in the same location I get odd glitches in the wall - sometimes on the interior and sometimes on the exterior. You guys dont get that? No, I have not experienced this. But for safety I would move the duplicate to a new layer and turn it off in 3D Link to comment Share on other sites More sharing options...
