johnny Posted November 15, 2016 Share Posted November 15, 2016 I have builder clients who often want to flip a home previously designed for a different lot. Flipping the plans isn't a problem, but what is a problem is the notes etc on the elevations/sections. Is there any solution for this? Link to comment Share on other sites More sharing options...
glennw Posted November 15, 2016 Share Posted November 15, 2016 Johnny, Are you using Reverse Plan to do the flip? Try this. Open up all your elevations and sections, and then do the Reverse Plan. Things should flip with a lot more order. You can even do the Reverse Plan from an elevation view. Edit: It appears that you don't even need to keep the elevations open. As long as you have opened and closed an elevation in that session, the text and dimensions behave. Chief seems to remember if an elevation has been opened it that session. http://screencast.com/t/Tr8AtgJL Link to comment Share on other sites More sharing options...
michaelgia Posted November 15, 2016 Share Posted November 15, 2016 However..... if you've done a layout already, be prepared for "reverse plan" to wreak havoc on your layout pages. You have to delete a lot of views and resend them to layout. Not an extremely big deal but it does require some work. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 15, 2016 Share Posted November 15, 2016 I wonder if having always update and the layout open would cover the opening of the each elevation and section. Haven't tried it . Link to comment Share on other sites More sharing options...
ShaneK Posted November 15, 2016 Share Posted November 15, 2016 No matter how you do it there will be work cleaning up items, elevations or text or dimensions or ??? but it's better than a re-draw. 1 Link to comment Share on other sites More sharing options...
johnny Posted November 15, 2016 Author Share Posted November 15, 2016 Thanks guys - and special thanks to Glenn for the video. That got me a lot closer. Link to comment Share on other sites More sharing options...
