michaelgia Posted November 11, 2016 Share Posted November 11, 2016 Hi, ever so generous and helpful core of experienced users. So, when I draw a 2x6 support wall with footing in a basement, the dotted footing line wraps around nicely at the ends. However, if I then connect a regular non-footing interior wall at the end at 90°, the new wall clips the footing flush with the end of the wall which has the footing. My work around is to add a slab footing at the end of this wall to extend it, but is there a better way? Am I missing something? (I can upload a pic, if necessary) Thanks in advance! Link to comment Share on other sites More sharing options...
Evolution Posted November 11, 2016 Share Posted November 11, 2016 A pic would certainly help, but posting the plan (even if you have to strip it down) would likely be quicker unless the REAL guru's on here have experienced it first hand? Link to comment Share on other sites More sharing options...
michaelgia Posted November 11, 2016 Author Share Posted November 11, 2016 Here is a screenshot. The darker grey wall is a standard interior-6 with "foundation wall" checked, giving it a footing of 30" wide. The perpendicular wall is a standard Interior-4. Link to comment Share on other sites More sharing options...
dshall Posted November 11, 2016 Share Posted November 11, 2016 Extend wall with footing out another 4', break wall at intersection, define extended wall as invisible, resize extended invisible wall with footing to taste...... do I get a point for this? Link to comment Share on other sites More sharing options...
dshall Posted November 11, 2016 Share Posted November 11, 2016 And here is a dumb video for those that can not understand my written explanation. https://youtu.be/XHLC6D-YNTY 1 Link to comment Share on other sites More sharing options...
Northriver Posted November 11, 2016 Share Posted November 11, 2016 Anyone who takes the time to do a video gets a point from me. Link to comment Share on other sites More sharing options...
michaelgia Posted November 12, 2016 Author Share Posted November 12, 2016 And here is a dumb video for those that can not understand my written explanation. https://youtu.be/XHLC6D-YNTY Thanks once again Scott! Definitely quicker than adding slabs every time. Wish Chief would just put a handle on the end of the footing so we could simply drag it past whatever length we need. Great video! Link to comment Share on other sites More sharing options...
Solution glennw Posted November 12, 2016 Solution Share Posted November 12, 2016 Here is another way. It looks like you either need the invisible wall as per Scott's method, or the broken wall using my method. Both ways use a different technique. Scotts uses the normal footing under an invisible wall. Mine uses the footing width for a small wall length. Choose your poison. http://screencast.com/t/hhUl7VfP0oL 2 Link to comment Share on other sites More sharing options...
michaelgia Posted November 12, 2016 Author Share Posted November 12, 2016 Hi Glen, your method is definitely more efficient since as soon as you add a footing on the small wall section/piece it matches up exactly to the right length, however, it messed up when I added a door that spanned across that little section of wall. I think I have to go back to regular wall with a slab across the length that I need. Which is, by the way, 12" past the end of the wall. Too bad, I was excited at first. Link to comment Share on other sites More sharing options...
glennw Posted November 12, 2016 Share Posted November 12, 2016 Ah...sounds like you aren't using a foundation plan - or you wouldn't be having the door problem. I would recommend you use a foundation plan - although I know others will disagree. Link to comment Share on other sites More sharing options...
michaelgia Posted November 12, 2016 Author Share Posted November 12, 2016 You are absolutely right. I'm ashamed to say I tried to cheat and incorporate my finished basement plan along with my foundation plan. In that case I'll take the extra 15 minutes to produce a separate foundation plan and use your method for extending footings. Pretty ingenious method you came up with there sir. Sweet and simple. Link to comment Share on other sites More sharing options...
glennw Posted November 12, 2016 Share Posted November 12, 2016 Does this mean that Scott gets his points deducted and awarded to me? ...yeah! Link to comment Share on other sites More sharing options...
dshall Posted November 12, 2016 Share Posted November 12, 2016 Does this mean that Scott gets his points deducted and awarded to me? ...yeah! Nice job Glenn, I gave you a point, you method is better. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 12, 2016 Share Posted November 12, 2016 You know a couple versions back we used to be able to drag just the footing to make it wider and longer but for some reason it's gone now, what happened? You could make conc. pads etc. just by reshaping the footing. Link to comment Share on other sites More sharing options...
dshall Posted November 12, 2016 Share Posted November 12, 2016 Glenn, I could not repeat what you did. I am not sure if you built a foundation or not. Would you mind doing one more vid from the very beginning to show how you built the walls and then built footings? Thanks. Link to comment Share on other sites More sharing options...
michaelgia Posted November 12, 2016 Author Share Posted November 12, 2016 I think if you're going to have a separate foundation plan, all you need to show is the footings under the support wall anyway. The foundation contractor doesn't need to see the actual support wall - he doesn't care. As such I've gone back to just drawing slabs for the footings. I can shape them anyway I want, like a p-solid. The support walls are just standard walls with no footings. I can chose to show them together with the slab or not. ....until chief decides to give us a handle at the ends of the footings, or makes it so it doesn't truncate inexplicably at the ends when joining to other walls. No big deal either way. Link to comment Share on other sites More sharing options...
dshall Posted November 12, 2016 Share Posted November 12, 2016 You know a couple versions back we used to be able to drag just the footing to make it wider and longer but for some reason it's gone now, what happened? You could make conc. pads etc. just by reshaping the footing. You are correct... however...... I was able to do it but it was not consistent behavior. So funny, the first time I tried it, it worked perfectly, but I have not been able to repeat the ease in which I did it the first time. I think I will wait for a vid from Glenn to find out his methodology and then I will tackle this again. Link to comment Share on other sites More sharing options...
dshall Posted November 12, 2016 Share Posted November 12, 2016 I think if you're going to have a separate foundation plan, all you need to show is the footings under the support wall anyway. ....... That is the way I do it every day, very few issues. However, for some reason you threw a kink it the methodology and now I am struggling to do what you would like to do...... and the problem with Glenn's method is that the top of the EXTENDED footing is level with the top of slab and of course I would like to control the top of the extended footing to say...... 12" below top of slab. I wish I could replicate Glenn's model. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 12, 2016 Share Posted November 12, 2016 I think if you're going to have a separate foundation plan, all you need to show is the footings under the support wall anyway. The foundation contractor doesn't need to see the actual support wall - he doesn't care. As such I've gone back to just drawing slabs for the footings. I can shape them anyway I want, like a p-solid. The support walls are just standard walls with no footings. I can chose to show them together with the slab or not. ....until chief decides to give us a handle at the ends of the footings, or makes it so it doesn't truncate inexplicably at the ends when joining to other walls. No big deal either way. I actually use a reference set to show all the walls in a very light gray color on the foundation plan, very handy and easy to add new footings where needed. Link to comment Share on other sites More sharing options...
glennw Posted November 12, 2016 Share Posted November 12, 2016 We can still drag the width of a footing - not the length. I am not sure that we could ever drag the length? Here is a bit more from the beginning. http://screencast.com/t/XDkFFCVSeu Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 13, 2016 Share Posted November 13, 2016 Here is a video I did earlier this year, about it not working http://www.screencast.com/t/UMDYTnLkOP Link to comment Share on other sites More sharing options...
