Story Pole set Top of Footing to 0?
michaelgia
Go to solution Solved by glennw,
Yes I think it would be possible but depending on how far along you are with the plan it might be easier to do a manual Story Pole.  Otherwise you would have to raise everything the distance between the existing top of footing and sub floor.  I have not gone through this whole process so you could run into complications.  Maybe someone with more experience will comment.
Question for all you architects then (I'm a lowly builder), isn't the top of the footing the "zero" level by convention?
Seems to be what I see on most plans up here in the extreme north east anyway.
Or even top of slab for commercial slab on grade construction...
Seems I've never seen a plan with main floor plywood as "0".
