Kduke11 Posted November 1, 2016 Share Posted November 1, 2016 Now that I'm working with CA every day I'm seeing what makes things quicker. Coming from AutoCAD I'd like to be able to select an object in CA and hit "E" to Delete it with out have to have other menu bars come up. Can I assign the Delete to a short key? Link to comment Share on other sites More sharing options...
HumbleChief Posted November 1, 2016 Share Posted November 1, 2016 Why can't the 'delete' key serve as your hot key for delete? Link to comment Share on other sites More sharing options...
Kduke11 Posted November 1, 2016 Author Share Posted November 1, 2016 Why can't the 'delete' key serve as your hot key for delete? LOL Too far away on the keyboard. keep one hand on mouse and other on keyboard. Just faster using "E" to delete/erase. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 1, 2016 Share Posted November 1, 2016 LOL Too far away on the keyboard. keep one hand on mouse and other on keyboard. Just faster using "E" to delete/erase. Totally get that. Not at the right computer now but can a 'Hot Key' be assigned to delete? Or is that your question. I think I would prefer another key myself. Need to explore. Link to comment Share on other sites More sharing options...
glennw Posted November 2, 2016 Share Posted November 2, 2016 I am pretty sure you cant assign Delete to a hotkey. Assigning a command to a single hotkey is not really a good idea if you want to build up your hotkey usage. Once you assign a command to say, the E key, it precludes you from using any other multi key commands that start with E. Link to comment Share on other sites More sharing options...
dshall Posted November 2, 2016 Share Posted November 2, 2016 I am pretty sure you cant assign Delete to a hotkey. Assigning a command to a single hotkey is not really a good idea if you want to build up your hotkey usage. Once you assign a command to say, the E key, it precludes you from using any other multi key commands that start with E. That is so true. So I would recommend 2 key hot keys. Change the delete to a EE hot key. Easy Peasy. Link to comment Share on other sites More sharing options...
glennw Posted November 2, 2016 Share Posted November 2, 2016 Scott, As I said, I don't think you can assign Delete to a hotkey. Link to comment Share on other sites More sharing options...
JJohnson Posted November 2, 2016 Share Posted November 2, 2016 In the interest of economy of motion; I use "Key Tweak", to reassign keyboard keys, and have a delete instead of whatever the thing is that is native to key 1 (not number 1 key), at keyboard left side I also have a ', or foot button now, at key 95, above the 8 on the number pad. I also have my mouse wheel to left assigned to delete, and to right to undo. Click wheel is 'open object' Mouse side buttons are, space bar (return to select) and tab key (next object) All this saves me countless mouse hand to keyboard or reach across keyboard moves. 1 Link to comment Share on other sites More sharing options...
dshall Posted November 2, 2016 Share Posted November 2, 2016 Scott, As I said, I don't think you can assign Delete to a hotkey. I am wrong again, thanks Glenn..... I misread your initial post and I did not verify.... Link to comment Share on other sites More sharing options...
