GeneDavis
Schedules blow out, way way out, right hand end. Bug or feature?
I have a window schedule and a door schedule in my plan, and Chief is blowing the right end out to infinity.  Not when first generated, but later when I work with the plan.
I did schedule-to-text and that is what I am putting on my layout, but in order to keep the unit numbers (which are only there when schedules are generated) I have to keep the live schedules.  Even those got their right margins extended, but not to the moon as the live schedules.
The pic attached shows how this looks.  The little bit of plan seen is floorplan surrounded by a terrain of about 120 x 120 feet.
Yes this used to happen to me all the time, I did get them to stop doing that.  Try putting them in a cad detail ( keeping them separate) instead of on the floor plan where moving something might be the culprit. Then send the cad detail to the layout. you can also put more than one in the cad detail, they also update automatically.
Good idea, Perry.  I'll try that.
I started a ticket with support and sent them the file.
We had this, cause was carriage return(s) in label or other user input in components list. Think they got there pasting.
Yeah, I've got user input in comments, the rightmost field.
What's that comment field for, if not the user to write something in? Can't recall doing a CR at the end of any, but I'll go and re-do.
Thanks, Mark. I'll report to service in Idaho, too.
Try removing that column from the schedule, if growing stops the problem is there. Then copy comments into word processor and turn on hidden characters. Was last year, but that what I think I remember.
Gene, just ran a test and I can't make it happen again-go figure. Have sent a message off to my assistant to see if either he remembers or what plan it was (was one he worked on) Will let you know if we find it again.
I cut the door schedule and the window schedule from the first floor plan view and then pasted them into a CAD detail window.  No jumps since.
This plan has problems.  They may be the result of me using material regions to do gable-end board and batten detailing.  It is the only part of the modeling that did not go well, and I suspect it has something to do with the schedule blowouts.
A couple of times when trying to cut a material region, I would do the polygon, then do the conversion to an MR, spec the layers, and the MR would not appear at all.  I would look and lo and behold, I would have an object 12,000 inches to the east in outer space, and it would be the MR.
Sounds fun. Heard back from my guy-he's checking for the file but said he remembers carriage returns as the problem. Yours may well be different, as I remember we already had the schedule in a CAD detail.
Check you distance from absolute zero in the plan. That is a cause for problems like that.
That's good to know P. Heard back from my guy and he found it- was that he pasted "tab" into the field- grows like a beanstalk-worst if there's a tab at the end of the line.
Just reproduced it.
Just reproduced it.
I have been requesting for years that "Tab" characters (like a little arrow) be made visible so that we can see where they are. It's pretty bad with standard text to find these. Maybe X9.
    27882
    Boots9
    Boots9
