LeeDrafter Posted September 23, 2016 Share Posted September 23, 2016 Hi All, I am working on townhomes that are exactly the same on both sides. I need the room dimension labels to be the same on my "advertising" plans or people will get confused and wonder why they are different. The actual dimensions are exactly the same, but I don't want to show people all the dimension lines for advertising. As you can see in the attached, both living rooms are actually 13' 10-1/2" X 16' 9-1/2". The room labels are rounding to 16'8" on one side and 16'-9" on the other side. I don't care if it rounds up or down, but I do need it to be the same on both sides. Does anybody know how to fix this? I am working in X5. Thanks! LOTS 112&113 BIGFORK LANDING.zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 23, 2016 Share Posted September 23, 2016 That is the reason I do not use that tool, if you want them the same, then manually make them the same. DJP Link to comment Share on other sites More sharing options...
tommy1 Posted September 24, 2016 Share Posted September 24, 2016 I agree with David. Link to comment Share on other sites More sharing options...
Dermot Posted September 24, 2016 Share Posted September 24, 2016 The plan you have attached is empty. A zip file that's only 164 bytes can't have anything in it. My guess is that you had the plan open when you tried to zip it. You may want to try reposting the plan to get a better answer then a random guess. There is a possibility that your rooms are not really the same size. There is also a possibility that this is something that works better in X8 then it does in X5. There is also a possibility that this is something that the program needs to handle better. No one is going to know for sure unless you post the plan. Link to comment Share on other sites More sharing options...
LeeDrafter Posted September 26, 2016 Author Share Posted September 26, 2016 Thanks for the replies. Still crossing my fingers that this is fixable so I don't have to remember to change the labels manually every time I make a change. I forsee myself missing a lot of corrections, but I suppose I would get used to it after a while. I have attached a better zip file. Thanks! LOTS 112&113 BIGFORK LANDING.zip Link to comment Share on other sites More sharing options...
Dermot Posted September 26, 2016 Share Posted September 26, 2016 This works better in X8. The room dimensions are both rounding the same now. You might want to consider upgrading. Link to comment Share on other sites More sharing options...
CharlesVolz Posted September 26, 2016 Share Posted September 26, 2016 Howdy Lee, No problem here in X8 when changing dimension defaults to 1" rounding (Primary Format/Accuracy/Smallest Fraction). Link to comment Share on other sites More sharing options...
