sarge75801 Posted May 30, 2014 Share Posted May 30, 2014 I have home designer architect and want to know if other than using a calculator, can the program tell me total square feet of a plan i design? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 30, 2014 Share Posted May 30, 2014 Yes just draw a p-line around it and open the DBX. No sure if HD has schedules, but if you do, the "Room finish Schedule has a SF category to add to the Sched. You can also use the living area, make sure it's checked in the CAD Defaults. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted May 31, 2014 Share Posted May 31, 2014 The Room DBX (on the general tab)in HD Titles also allows you to include/exclude the room in the calculated living space , but it maybe off by default ? check the 3 settings.... the HD Forum is here for more questions too ,same sign-in ID as here. https://hometalk.chiefarchitect.com/index.php?/forum/5-qa/ Link to comment Share on other sites More sharing options...
raltd9245 Posted May 31, 2014 Share Posted May 31, 2014 On 5/30/2014 at 4:21 PM, DRAWZILLA said: Yes just draw a p-line around it and open the DBX. No sure if HD has schedules, but if you do, the "Room finish Schedule has a SF category to add to the Sched. You can also use the living area, make sure it's checked in the CAD Defaults. That is the way I do it more accurate. Link to comment Share on other sites More sharing options...
dshall Posted May 31, 2014 Share Posted May 31, 2014 On 5/31/2014 at 6:21 PM, raltd9245 said: That is the way I do it more accurate. I agree with Ron, a closed pline is the most accurate way to go. Now if CA would just work it out so that the pline has a label that includes an area, we can take that macro and shuffle it around to our own area analysis text blocks. Hey CA, do us a favor and work this out, thank you, thank you very much. 1 Link to comment Share on other sites More sharing options...
raltd9245 Posted May 31, 2014 Share Posted May 31, 2014 On 5/31/2014 at 6:33 PM, dshall said: I agree with Ron, a closed pline is the most accurate way to go. Now if CA would just work it out so that the pline has a label that includes an area, we can take that macro and shuffle it around to our own area analysis text blocks. Hey CA, do us a favor and work this out, thank you, thank you very much. DSH, It's Saturday They aren't working today!!!! Ron Link to comment Share on other sites More sharing options...
GerryT Posted May 31, 2014 Share Posted May 31, 2014 On 5/31/2014 at 6:33 PM, dshall said: I agree with Ron, a closed pline is the most accurate way to go. Now if CA would just work it out so that the pline has a label that includes an area, we can take that macro and shuffle it around to our own area analysis text blocks. Hey CA, do us a favor and work this out, thank you, thank you very much. They already do. Just use the total "Living Area" label. Of course, not "included areas" will not be included there, But changes of getting labels on all objects are pretty slim -- IMHO. Link to comment Share on other sites More sharing options...
