CBuserIndia Posted September 9, 2016 Share Posted September 9, 2016 This, very likely, is not Chief Architect question, however if you guys have any tips for me, it will help alot.We keep multiple views for rendering over night time. These usually get over in couple of hours time. Say for example my rendering will go on for next 5 hours. However I force my laptop to stay awake for whole night.How do I make my laptop go-to Sleep after rendering is done.Right now I am using Power option >> Sleep >> "Never" in windows settings.We have multiple CA Interior 8 licenses. My team uses laptops with windows 8 & some with windows 10.Please if you have any smart tips for my laptops to go sleep after work is done. How do you guys handle this situation ?Thanks for helpNitin Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 9, 2016 Share Posted September 9, 2016 Others may suggest more exotic procedures but I would just render in the back ground while I worked on other plans, that way you can get your work done without any unusual measures to take. DJP 1 Link to comment Share on other sites More sharing options...
LevisL Posted September 9, 2016 Share Posted September 9, 2016 You could check out this program. I don't have any personal experience with it, so I can't say if it works as advertised. http://www.ampsoft.net/utilities/WinOFF.php I use an app with similar features on my Macs called 'Amphetamine'. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 9, 2016 Share Posted September 9, 2016 Nitin, My PC sometimes requires about ten or fifteen minutes for professional looking renders using its Ray-Tracer function. What software do you have? What is your PC hardware like? DJP Link to comment Share on other sites More sharing options...
CBuserIndia Posted September 10, 2016 Author Share Posted September 10, 2016 Thanks for suggestion, will give a try You could check out this program. I don't have any personal experience with it, so I can't say if it works as advertised. http://www.ampsoft.net/utilities/WinOFF.php I use an app with similar features on my Macs called 'Amphetamine Link to comment Share on other sites More sharing options...
CBuserIndia Posted September 10, 2016 Author Share Posted September 10, 2016 We are spending about 20-25 minutes to render single view. My team has got in to habit of completing design work & towards end of the day, keep 10-12 views for render. We use Standard Ray trace inbuilt inside Chief Architect Interior version. Not all machines/config are same. Typical hardware we have is : Intel i5 3rd Gen CPU, 8GB RAM, 1 TB Hard drive, 2 GB Intel graphics Card Thanks Nitin Nitin, My PC sometimes requires about ten or fifteen minutes for professional looking renders using its Ray-Tracer function. What software do you have? What is your PC hardware like? DJP Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted September 10, 2016 Share Posted September 10, 2016 Is there a particular reason you need the computer to go to sleep after the Raytraces are finished. You can set the screen to turn-off, this will not affect your Raytracing. Once the Raytraces are complete your system won't really be doing anything so it is just idling, not much power consumption if that is what you are trying to achieve. Graham Link to comment Share on other sites More sharing options...
CBuserIndia Posted September 11, 2016 Author Share Posted September 11, 2016 Is there a particular reason you need the computer to go to sleep after the Raytraces are finished. You can set the screen to turn-off, this will not affect your Raytracing. Once the Raytraces are complete your system won't really be doing anything so it is just idling, not much power consumption if that is what you are trying to achieve. Graham Thank you Graham, that sounds good. Link to comment Share on other sites More sharing options...
