KKB9750
Auto Dormer Question
Auto Dormer question:  I've got this strange display artifact going on where my auto dormer walls meet my interior walls.  Has anyone seen this before and what can I do to fix it?
I've attached a picture of the issue and the plan below.
Thanks!
dormer test.plan
Personally, this isn't a place where I would use an auto-dormer... in fact, I rarely use that tool.
I agree with JPC.  I build them manually.
However,  you might try EXPLODING (there is a tool at bottom left corner of screen available when you select the auto dormer) the auto dormer and then play with raising and lowering the roof planes.
Explode dormer / select roof plane / open dbx / adjust roof structure layer framing to 9 1/4". same as roof plane of house. All will be well after adjustments.
I have been complaining about the Rafters showing below the ceiling line for many versions now. The program just won't cut oversized rafters at that point. In almost every job I have the hips are much larger than the rafters ( because of bearing hips now), Just changing the hip size won't do it for me. I use framing labels and we need the actual size shown with a cut at the bottom. Right now I have to shut off the rafters in these interior views but then I don't get the rafters showing outside through the windows. Chief please fix the framing to be as it would be in real life.
Thanks Shane! This did the trick.
Point taken about building them manually in the future though.
If you need to have an accurate framing, this won't work, I hope Chief will fix this. the first post shows a hip or valley which we all know need to be a size larger than the rafter and Chief calls this a ridge and there is no way to have ridge hip and valley the same size, for me they are all different sizes, manually fixing these is all we can do at this point..
    27499
    Bren0625
    Bren0625
  • Similar Content
    • By ChiefArchitect
      This bathroom is upstairs, tucked into a dormer. You can see the adjacent roofs in the mirror reflections.
      Reflections like these can be controlled in the Material Properties, and displayed using camera specifications. PBR views like this one do a good job representing reflections in mirrors, and also reflections on shiny surfaces like counters, porcelain, and even metal. Other benefits of this rendering technique are high quality shadows and lighting, all combined with real-time rendering. This means you can navigation your scenes in front of a client or home owner and it will look as good from each angle.
    • By ChiefArchitect
      You'll notice that floor plan Option 3 and Option 4 for the Paradise Rises project are quite similar. Both are a story and a half with matching structural walls and feature livable attic space. The attic in Option 3 has been left mostly unfinished. This creates an opportunity for a home owner in Paradise, CA, to rebuild a livable space for themselves with cost savings by not immediately finishing the upstairs. Once they are prepared to complete the project, residents to can choose to wrap it up on their own accord.
      Review the full design set to see how the attic spaces differ between architectural styles due to the location and placement of dormers.
    • By Designer100
      client is wanting boys bedroom on 2nd floor. Egress will be thru dormer window after opening door. I cannot get the dormer thru automatice dormer to set in there.
      I would appreciate any help in designing a dormer to set in area landing.
      Thank you if someone can assist me.
      Newell Cheatheam
      Chief x11
      newell.cheatheam@gmail.com
      713.385.3622
      DuranRemodeling.plan
    • By Darlene
      Hi Everyone,
      I am a newbie and using Architectural 2019.  I placed a railing on the outside edge of my front porch and would like to delete it.  But, every time I try to delete it, the roof goes down to the ground on the porch area.  Can anyone help please?
      Thanks, Darlene
    • By MAINEWOOD59
      Hello,  I am using X-7.   I started moving walls around on the 2nd floor and got myself into trouble. exterior siding on the inside and holes in the exterior dormer walls.  Help please?
      Thanks
      Chieftalk_help.plan
