DianeP Posted August 10, 2016 Share Posted August 10, 2016 I can't remember the key(s) to use to cycle forward on the last electrical components used. I know esc key goes backwards. Can anyone help me remember the key to go forward? Link to comment Share on other sites More sharing options...
DianeP Posted August 10, 2016 Author Share Posted August 10, 2016 Any other short cuts you use to make the tedious task of electrical layout page simpler. If so, please share. It is my least enjoyable part of a project. Link to comment Share on other sites More sharing options...
Solution Gawdzira Posted August 10, 2016 Solution Share Posted August 10, 2016 I have hot keys set up for the electrical item placement. E,S = switch E,L = light E,R = outlet (receptacle) E,C = connection Link to comment Share on other sites More sharing options...
DianeP Posted August 10, 2016 Author Share Posted August 10, 2016 I have hot keys set up for the electrical item placement. E,S = switch E,L = light E,R = outlet (receptacle) E,C = connection Great idea, I will look up how to set hot keys. Thanks! Link to comment Share on other sites More sharing options...
Kelly_K Posted August 10, 2016 Share Posted August 10, 2016 Geez, I hate to sound like a broken record about multi-button mice, but thru button mapping I have taken a lot of the pain out of wiring a home. (with the exception of the wild connect arcs) Just like Alan I have created hot keys, assigned to my mouse - see the attached picture. Unlike Alan I needlessly complicated the hot key combination - the final letter points to the function like c - for connect, t - for 220 o - for outlet, etc. I also include 1 for break which I occasionally use to tame the arcs. Link to comment Share on other sites More sharing options...
DianeP Posted August 10, 2016 Author Share Posted August 10, 2016 Geez, I hate to sound like a broken record about multi-button mice, but thru button mapping I have taken a lot of the pain out of wiring a home. (with the exception of the wild connect arcs) Just like Alan I have created hot keys, assigned to my mouse - see the attached picture. Unlike Alan I needlessly complicated the hot key combination - the final letter points to the function like c - for connect, t - for 220 o - for outlet, etc. I also include 1 for break which I occasionally use to tame the arcs. Wow, looks like that would work well but there would be a learning curve for me. I am such a creature of habit with my left and right click mouse that has a scroll wheel. Did it take you long to adjust? Link to comment Share on other sites More sharing options...
Kelly_K Posted August 10, 2016 Share Posted August 10, 2016 Adjusting to mouse wasn't too difficult, it was memorizing the tool locations on the mouse. I just kept a cheat sheet in front of me until it became rote. Link to comment Share on other sites More sharing options...
DianeP Posted November 25, 2020 Author Share Posted November 25, 2020 On 11/12/2020 at 1:48 PM, rlackore said: On 8/10/2016 at 9:57 AM, Gawdzira said: I have hot keys set up for the electrical item placement. E,S = switch E,L = light E,R = outlet (receptacle) E,C = connection I hate when I don't notate what I did so I can refer back to it. I did create these hot keys for library symbols, Now I want to create more for other things in the library that I use often. I can't figure out how I did it. Any help is much appreciated. Thanks!!! Sorry about the second quote. I had two saved somehow and I can't see how to remove the other one. Link to comment Share on other sites More sharing options...
rgardner Posted November 25, 2020 Share Posted November 25, 2020 Combination of hot keys, mice keys with the hot keys and in the MEP configuration custom place library keys tied to predefined electrical items in my user library. Makes very short work out of an electrical plan. I have come to enjoy doing the electrical sheets. Link to comment Share on other sites More sharing options...
