Chief Architect capabilities question?
ajrare
If you import a standard DWG its typically in 2D - so to the extent you are looking for 2D then yes...otherwise if 3D then not really.  There are 3D attributes in DWG as well, but even then I think the best you'd get is a symbol in CA.
If whomever is sending you the CAD file can turn off all the layers except the main outer layer of the walls, then the CAD to WALLS tool works really quickly. Even if you have just the wall layers, and can shift select the outer layer it works. The outer layer of the CAD file will be the MAIN LAYER of your Chief walls.
