Dennis_Gavin
conc block section fill
The fill I get from a plan section of concrete block is different than what is offered in the CAD details.
I cannot find a fill pattern to match the detail. How can I get rid of the X hatch?
Look at the second mortar joint down, I'm saying that's all done by hand with p-solids to look more impressive than you can actually get from Chief OOB.
If you want the more detailed version you can simply copy and past on top of the wall section and extend or retract the area you need to fit.  However, if you are printing that section 1/2" scale or below its probably not worth it.
If you look in the library there is a folder called DETAIL COMPONENTS in the CAD Detail folder. There are individual block and brick in there that can be stacked to create details.
Did not Know that - thanks Joey.
    27501
    B1k3rm4n
    B1k3rm4n
