Scottb Posted July 10, 2016 Share Posted July 10, 2016 How do you make the chain longer on a chandelier? Link to comment Share on other sites More sharing options...
dshall Posted July 10, 2016 Share Posted July 10, 2016 On 7/10/2016 at 3:20 PM, Scottb said: How do you make the chain longer on a chandelier? Do you want to stretch out the chain or do you want to add additional links? Link to comment Share on other sites More sharing options...
Scottb Posted July 10, 2016 Author Share Posted July 10, 2016 I guess additional links would look the best. whats easier? Link to comment Share on other sites More sharing options...
dshall Posted July 10, 2016 Share Posted July 10, 2016 On 7/10/2016 at 3:49 PM, Scottb said: I guess additional links would look the best. whats easier? Adding links is harder. stretching existing much easier. Look at light in elevation and lengthen it and if the stretch plan is in correct location it is easy peasy. if not, it will take more work. Of course if you had posted the light fixture in a plan in the beginning, you would of had an answer much quicker. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 11, 2016 Share Posted July 11, 2016 Scott, I noticed you did not post a link to the instructional video of adding links. That would be a really great thing for cathedral ceilings. Chopsaw Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 11, 2016 Share Posted July 11, 2016 Not a video, but here's one way to extend the chain itself... 1. Drop the fixture into the plan, take a 3D overview, delete surfaces to remove the top piece, and convert to symbol. 2. Delete surfaces again, this time to remove everything except the top piece and some of the chain, and convert that to a 2nd symbol. 3. Drop the 2 new symbols into a plan, position them correctly, and then convert that to a symbol. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 11, 2016 Share Posted July 11, 2016 Thanks Michael, I like that as a practical solution as it gives a precise result. I little extra work to get a 10' chain for a 16' ceiling but doable. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 11, 2016 Share Posted July 11, 2016 If you can stay away from the "chain" and just have a "rod" or "cord" then a strategically placed stretch plane will work great. It's a lot easier. Link to comment Share on other sites More sharing options...
