FelthamUK Posted June 21, 2016 Share Posted June 21, 2016 Dear Members, A simple question that I cant seem to resolve! How do I stop walls snapping to each other; I may want them to snap to a line instead for example. BR Sean Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 21, 2016 Share Posted June 21, 2016 I think the answer to that question really depends on specifically what you're trying to accomplish. There are a few methods including using perpendicular/parallel walls as necessary, using alternating wall types, using a specific drawing order, using a specific series of operations, using no room definition walls (either permanently or temporarily), or even temporarily using an additional floor along with the reference display...I'm sure the list could go on. Can you elaborate a bit? Link to comment Share on other sites More sharing options...
FelthamUK Posted June 22, 2016 Author Share Posted June 22, 2016 Here's an example attached. Lets say the junction between thick cavity type wall and thin (yellow) wall should be where the line is drawn. Try moving the wall junction without deleting or moving the window. Link to comment Share on other sites More sharing options...
FelthamUK Posted June 22, 2016 Author Share Posted June 22, 2016 https://app.box.com/s/ntl6cuvyo5dk6d93dx1es0zdrexy4rzv Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 22, 2016 Share Posted June 22, 2016 You mean like this? Link to comment Share on other sites More sharing options...
glennw Posted June 22, 2016 Share Posted June 22, 2016 Joe, You beat me to it. Link to comment Share on other sites More sharing options...
FelthamUK Posted June 22, 2016 Author Share Posted June 22, 2016 I do. Mine snaps all over the place (except to the line). What do I need to do? Link to comment Share on other sites More sharing options...
glennw Posted June 22, 2016 Share Posted June 22, 2016 Drag a Room Divider wall perpendicular to, and at the end of the thick cavity wall. Then drag the Room Divider wall up to the cad line - the end of the thick wall will move with the Room Divider wall. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 23, 2016 Share Posted June 23, 2016 Actually, in this particular instance you dont even need the room divider wall. This is one of those cases where simply drawing in the correct order/sequence will address the issue. Here's a quick crappy video... Link to comment Share on other sites More sharing options...
FelthamUK Posted June 23, 2016 Author Share Posted June 23, 2016 Thank-you so much all. Wow, so many helpful people on this forum, really cool! Link to comment Share on other sites More sharing options...
