Wall Hatch
helavagal
Are you sure you're referring to actual hatching or are you perhaps just referring to the fill?
If its the fill you're referring to, you'll need to check "Print In Color" in the Print Layout dbx.
The Walls, Hatching layer only controls hatches that are added via Build>Wall>Hatch Wall.
I print in color using "color off is grayscale". That way everyone gets it in color and your printer can print in grayscale. I can also check my colors and see what shade of grayscale that color will print as.
