BFogarty Posted June 7, 2016 Share Posted June 7, 2016 Is it possible to add more than one window unit to the standard "box window" in X7? Thx! Link to comment Share on other sites More sharing options...
justmejerry Posted June 7, 2016 Share Posted June 7, 2016 I believe you are limited to what you see. However you can switch the window to be a double casement or triple if that works for you. The other option would be to put your own walls and windows as needed. Link to comment Share on other sites More sharing options...
javatom Posted June 7, 2016 Share Posted June 7, 2016 Yes, you can stack windows on top of each other. They can also be designated level 1 or 2. It may bee easier to place it in elevation mode so you can see which window you have grabbed. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 7, 2016 Share Posted June 7, 2016 Yes IF you draw the bay window manually, the box-bay window object is VERY limited in terms of customizations. DJP Link to comment Share on other sites More sharing options...
dshall Posted June 7, 2016 Share Posted June 7, 2016 Yes IF you draw the bay window manually, the box-bay window object is VERY limited in terms of customizations. DJP Wow, I thought it was just the opposite. Build the bay manually and the world is your oyster..... except for a few minor limitations..... but better that than auto bays...... Link to comment Share on other sites More sharing options...
BFogarty Posted June 7, 2016 Author Share Posted June 7, 2016 Any tutorials out there for a manual Box Out Window? I can't find anything David- I agree, that box out with the program is pretty useless Link to comment Share on other sites More sharing options...
BFogarty Posted June 7, 2016 Author Share Posted June 7, 2016 Wow, I thought it was just the opposite. Build the bay manually and the world is your oyster..... except for a few minor limitations..... but better that than auto bays...... Scott- Would you draw a box out the same as a bay manually? If that's the case I think there's plenty out there. Link to comment Share on other sites More sharing options...
Solution BFogarty Posted June 9, 2016 Author Solution Share Posted June 9, 2016 This video by Mr. Hall certainly helped clear up my questions with this. "Mark's Bay Window" https://www.youtube.com/watch?v=7yFSBeL7Hlw Link to comment Share on other sites More sharing options...
