Material Region pattern not showing
MarkMc
Go to solution Solved by TheKitchenAbode,
  • Solution
Mark - There was a discussion about something like this a few months ago. One user suggested changing the % shading on the pattern so it will show. I played with this problem and concluded that it is related to the generic sun and the vector elevation mode. Try the shading change, I think this is the only current solution.
Graham
Mark - For some odd reason the generic sun can't be accessed/adjusted if the elevation is in vector mode. It works if you select standard or any of the other render types. In vector the generic sun is fixed at a specific angle, the only way is to rotate your plan instead of the sun.
Graham
