Migaloo Posted June 1, 2016 Share Posted June 1, 2016 I have not seen this before but when I send my layout to print it is stretching the layout and compressing it. Can't seem to figure out what is causing it. Link to comment Share on other sites More sharing options...
lbuttery Posted June 1, 2016 Share Posted June 1, 2016 Jim: you will probably have to post the plan and layout otherwise, everyone is just guessing does your drawing sheet match the layout size ? MENU - FILE - PRINT - DRAWING SHEET are you printing to PDF first ? if not, you should Lew Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 1, 2016 Share Posted June 1, 2016 it will be your printer settings set to fit to page or something, or printer page set wrong. are you printing to printer or pdf?? Link to comment Share on other sites More sharing options...
Migaloo Posted June 1, 2016 Author Share Posted June 1, 2016 I am not printing to pdf. I have been printing to printer for several years with no issues. I recently had to reload os on computer and this is first time I have tried to print since the reload. Link to comment Share on other sites More sharing options...
lbuttery Posted June 1, 2016 Share Posted June 1, 2016 Jim: ok, once you have your issue settled take some time and give serious consideration to printing to PDF first many, many advantages better than sliced bread Lew Link to comment Share on other sites More sharing options...
Evolution Posted June 1, 2016 Share Posted June 1, 2016 I always print to PDF first. WOW does it make a difference! Link to comment Share on other sites More sharing options...
Migaloo Posted June 1, 2016 Author Share Posted June 1, 2016 Ok I printed to pdf and it worked fine. Just a couple of extra steps. Link to comment Share on other sites More sharing options...
lbuttery Posted June 1, 2016 Share Posted June 1, 2016 Jim: yes, but if you save the PDF you will have an archive of exactly what was printed at that time you can also email the PDF to others including the print shop I also use PDF's to capture web sites for archiving or reading later PDF can be printed in color - then when sending to printer you can choose color or B/W you can choose exactly which pages to print using PDF's eliminates most printer driver issues Lew Link to comment Share on other sites More sharing options...
Solution Migaloo Posted June 1, 2016 Author Solution Share Posted June 1, 2016 Thank you. I can see more advantages than disadvantages with. It just drives me crazy to not know why it doesn't print right the other way. Jim Link to comment Share on other sites More sharing options...
