wolftide45 Posted April 2, 2016 Share Posted April 2, 2016 The ptp tool will dimension to walls, similar to the manual dimension tool, but I thought the ptp tool relocates freely to whatever point the marker is moved. I cannot move the marker at all unless it locates a wall. What setting am I missing? Thx Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 2, 2016 Share Posted April 2, 2016 You must zoom in to select a point marker, once it is selected you can move it by dragging or using the dimension string to locate it. The marker is just an object like any other but due to it's own dimensions it is hard to select unless you zoom in to do so, that is the key and has nothing to do with walls or any other object. You just do it. DJP 1 Link to comment Share on other sites More sharing options...
wolftide45 Posted April 2, 2016 Author Share Posted April 2, 2016 The way you've explained it is the way I've always been able to use it. Select the marker and use the drag handle to place the marker where I needed it to be. For some reason, I cannot do it currently...I've enclosed a plan template that I use, maybe you can see what I'm talking about....thx David PTP.plan Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 2, 2016 Share Posted April 2, 2016 try to re-start Chief, happens once and a while for me. I rarely use the p to p dim. tool and really only when lines are not parallel to each other. Link to comment Share on other sites More sharing options...
wolftide45 Posted April 2, 2016 Author Share Posted April 2, 2016 good suggestion, didn't work however. Also, tried x6 as well. Not working there either. It has always worked for me before, a bit puzzling. Link to comment Share on other sites More sharing options...
Solution wolftide45 Posted April 2, 2016 Author Solution Share Posted April 2, 2016 ok, I got it. David, you were all over it, thx. I finally drew a selection box over the marker and realized I wasn't selecting the marker but the dimension line. as long as you still have the ptp tool selected, I don't think you can select the marker. once you select the normal pointer tool you can select any leg of the marker and drag and move it. thx guys for the help Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 2, 2016 Share Posted April 2, 2016 ...as long as you still have the ptp tool selected, I don't think you can select the marker. once you select the normal pointer tool you can select any leg of the marker and drag and move it... You are correct. The key is to be in either Select Objects mode (Space) or using the point marker tool. Either of those will allow for very easy selection of that point marker. Link to comment Share on other sites More sharing options...
MickeyToo Posted April 3, 2016 Share Posted April 3, 2016 ...as long as you still have the ptp tool selected, I don't think you can select the marker. Actually you can. You just have to right click when the cursor is over the marker. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 3, 2016 Share Posted April 3, 2016 Actually you can. You just have to right click when the cursor is over the marker. Hey, that's an interesting little trick. Thanks. BTW, just realized holding down control does the trick as well. Link to comment Share on other sites More sharing options...
MickeyToo Posted April 3, 2016 Share Posted April 3, 2016 Actually, Michael, I think the recommended way in Chief to select any object is with a right click (saw it in one of the videos once), but that to me is counter intuitive and really takes some getting use to. But then again maybe this is in instance where it make sense. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 3, 2016 Share Posted April 3, 2016 Actually, Michael, I think the recommended way in Chief to select any object is with a right click (saw it in one of the videos once), but that to me is counter intuitive and really takes some getting use to. But then again maybe this is in instance where it make sense. Ya, now that you mention it that's how I recall they first teach you to select things in the users guide. I quickly abandoned that technique pretty early on though and now I only ever use it when I'm having a tough time finding a particular edit tool. I'm wondering now if I should consider using it more often. It's really not a bad technique and might be quicker in some circumstances. Thanks Mickey...Is Mickey your name? Link to comment Share on other sites More sharing options...
MickeyToo Posted April 3, 2016 Share Posted April 3, 2016 It's a nick name I was given when I played baseball in school. I was a switch hitter (not all that good) and there happen to be switch hitter at the time who played for the Yankees who was very, very good. It just stuck. Real name is Bill though. I agree that learning to use the right click to select things is Chief is probably going result in increase productivity in the long run. But when you are left clicking in every other program it is tough to make the transition in Chief. I do try to remember to right click whenever I am having trouble selecting things, however. Link to comment Share on other sites More sharing options...
