Report bugs?
johnny
Johnny,
I'm not sure that is a bug.
Looks to me like it is the Countertop Height setting.
When you drag the copy off to the side, it is no longer relative the slab and looks like it drops down relative to the terrain.
I believe the default setting is Set Height From Cabinet.
If you uncheck Set Height From Cabinet, you can specify one of the other height settings.
You will probably find that Absolute may be the best because then it makes difference if there is a floor, deck, terrain, etc, under the object. This setting relates to Chief's zero height - usually the first floor level.
http://screencast.com/t/X1vpKHykW6h
Arrgh! - lost the sound, but it becomes pretty obvious.
