Changing room labels
capitaldesigns
I'm new to Chief. I'm using X-8,
When you identify a room  in your plan, Chief automatically places a room label with the name and room size.
Is there a way to change the text size of each the room name and the room dimensions? I would like to make to
room dimension text smaller than the room label text.
Also is there a way to show the ceiling height under the room name instead of the room size?
Thanks,
Mike
That worked. Another couple of questions. I see that using the rich text method the room title uses smaller cased text for most of the title unlike the automatic room title which uses all capital
letters. Is there a way to have the rich text macros use all capital letters on the title portion of the room label.
Second question, is there a way to change the room title itself using the rich text method? For example the Family Room label only shows the title as Family. Is there a way to have the macro show the title as Family Room?
Thanks,
Mike
