KevinRAmbrose Posted March 9, 2016 Share Posted March 9, 2016 So I have a 40" 4K tv running on a GTX970 card - it looks beautiful but when i try to select and draw in chief, the mouse is like dragging through molasses. i upgrade to a 10,000 DPI mouse and cranked up the dpi to compensate for the shear number of pixels to traverse and still seems like molasses, it only seems to be Chief, I run Fusion 360 and don't have the same issue nor in just standard windows programs, I even noticed that the lag seems to ga away when i am over toolbars in Chief, so just seems to be the drawing environment/area. has anybody else experienced this on higher resolution monitors? Link to comment Share on other sites More sharing options...
KevinRAmbrose Posted March 10, 2016 Author Share Posted March 10, 2016 An update on my slow as molasses problem, i thought to my self what slows the cursor down when i go from menus to drawing area so I turned off cursor coordinate tracking and crosshair, seems to have substantially reduced lag Link to comment Share on other sites More sharing options...
KevinRAmbrose Posted March 10, 2016 Author Share Posted March 10, 2016 Another update, anything that requires the software to visually update the graphics based on cursor position, like drawing a cad box, will show a slight lag, it seems to me that with the speed of todays computers that Chief's routine for updating based on cursor position may need some t Link to comment Share on other sites More sharing options...
Greg_B Posted March 11, 2016 Share Posted March 11, 2016 I don't think there is a limitation in CA with this many pixels. I'm commonly using far more pixels than that without the problem. Currently using 4800x2560. I was recently playing with 5760x1920. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 11, 2016 Share Posted March 11, 2016 There are a couple of things I would check. 1. The mouse settings 2. Make sure the NVidia Graphics Card is actually in control. Open the NVIDIA Control Panel and select "Configure Surround, PhysX". In the PhysX Settings make sure the NVidia GTX970 is shown as the Processor. It's possible that when you installed this monitor it didn't get the NVidia assigned to it. One other thing to check is the amount of memory in your GPU. I recommend at least 3GB. Link to comment Share on other sites More sharing options...
magued Posted March 30, 2016 Share Posted March 30, 2016 we were using SEIKI 4K monitors and had the same issue with the mouse. Monitor died. It was replaced with a Samsung 4k and the problem suddenly went away. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted March 30, 2016 Share Posted March 30, 2016 Might be worth checking in Device Manager under Display to see if the driver is specific for your monitor or a generic driver. If it is generic you can search the monitor manufactures site to see they have a specific driver and install it to see if there is a difference in performance. Graham Link to comment Share on other sites More sharing options...
