export elevation to layout
JeanTurcotte
I turn off labels for that which helps.
Can also temporarily change default doors and drawers to slab, export to layout, print to pdf OR save as and never let the elevation update, then change the plan back to the original default doors (undo works quickly)
In some cases I will copy the entire run of cabinets to another wall somewhere- make all doors and drawers openings with no shelves- then convert that to CAD
That should not happen.
Here's what I suggest:
- check to see if your cabinets are very far from the plan origin (0,0).  The only time I have seen big problems with send to layout is when everything is way out in Timbuktu.
- post your plan.  Someone can see if they get the same results.
- send your plan to tech support.  It looks like a bug to me.
